2015 Prius V electronic key lost transmission with the vehicle
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by AVN, Jul 29, 2019.
  1. AVN
    AVN New Member
    Princeton, NJ
    2015 Prius v wagon
    The electronic key stopped working after the car was not used for 5 weeks. The key is not detected. How to determine whether the transmission between the key and the vehicle is being blocked, or the key battery is dead? How to restore the key-vehicle transmission?
  2. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    Get a multi-meter and check the voltage on the battery.
    Do you have another functioning key? Try it out for function check.
  3. fuzzy1
    10,045
    (1) Try using the dead-fob-battery method of opening and starting the car. Use mechanical key (in fob on keyring loop) to open the door. To start engine, press brake to wake up the electronics, hold fob to the start button so that the very-short-range RFID detection works, then start car. If this works, then a dead key fob battery is the most likely explanation. (the multi-meter mentioned above is better, but not everyone has it available.)
    (2) Did someone turn off the Smart Key System detection before the trip? Check, and turn it back on if necessary. This is done from the vehicle setup menu on the big screen of my Liftback, but your 'v' would have different menus.
    Air_Boss likes this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,783
    2017 Prius c
    Most likely that the 12 V battery has gone dead in the car.
    Have that tested first.
    If you do NOT have a second remote key, GET one soon.
    If you lose both......or both go bad......it is a VERY expensive thing to fix.
  5. bisco
    48,988
    welcome to PriusChat!
  6. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    You might have to pair it again. I think you have to hold it on the push start button. There is a tutorial I think I'm the manual.
