2017 Prius - Liftgate wiring grommet plastic clips or whole assembly
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by John Peterson, Dec 2, 2024.
  1. John Peterson
    John Peterson New Member
    Atlanta
    I am in search of the part number for the plastic clips that secure the passenger side rubber wiring protector to the body and liftgate on the 2017 Prius 3 (assembly may be shared across the Gen 3 platform). This assembly exists in a very similar form on the driver and passenger side.
    I carefully unseated these to ease the process of routing a dashcam rear camera cable and am now unable to reseat the rubber gaskets around the plastic part/clip in that area. I have searched through multiple diagrams for the 2017 Prius and cannot find this part detailed clearly. I would be grateful for either the part number for this assembly, the plastic clip parts, or suggestions on how to get the rubber to reseat around the existing plastic clips.
  2. John Peterson
    Atlanta
    Found it in a diagram but now part numbers don't show up on internet - parts listed as 82818Q (left) and 82818R (right). It's unclear if the part linked to in this catalog listing has anything to do with the 86101Q assembly referenced in the diagram. Google comes up empty when "86101Q toyota" is entered. #82817-47L50 is the part that shows this diagram on autoparts toyota com.
  3. Tombukt2
    Tombukt2 Senior Member
    13,730
    2,484
    Durham NC
    Put some goop on the offending parts and set them down where you want them and let it dry 30 minutes and they'll be there until you rip them up again.
