2018 Toyota Prius 4 Touring= Alarm?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Vrooom23, Jul 26, 2023.
  1. Vrooom23
    Vrooom23 New Member
    2018 Prius
    Four Touring
    I have a 2018 Toyota Prius Four Touring. The fob has a red button that has an alarm and a lock/unlock button.
    Today while my car was locked, the window was broken and theft opened the door to break into the car. Should the car have a stock alarm? Should the alarm have gone off?
  2. Tideland Prius
    16,445
    No. What you're thinking of is an extra "glass breakage sensor" that is sometimes offered as a dealer-installed accessory on some Toyotas.
    The standard Toyota "theft-deterrent system" is tied to the door locks and will only sound if the door locks are forcibly unlocked (or the door is forcibly opened).
  3. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Wait, so the factory fitted alarms in the US don't have ultrasonic sensors to detect motion inside the cabin?
  4. Tideland Prius
    16,445
    Neither that nor a glass breakage sensor.
  5. Vrooom23
    Vrooom23 New Member
    2018 Prius
    Four Touring
    I appreciate your response! That sounds ridiculous, so I'm not quite sure I understand the purpose of the alarm.
  6. Tideland Prius
    16,445
    It’s for that one specific scenario where a thief would use a coat hanger or similar to unlock the door from the outside. It also does include an engine immobiliser.
    jerrymildred likes this.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    In fact, I usually refer to that red blinking light on the dash as the "immobilizer" light.
    Tideland Prius likes this.
  8. Tideland Prius
    16,445
    I think that’s the main function. The fact that it’s partially associated with an alarm is a byproduct.
