2021 Prius Clockspring/Steering Wheel wiring Diagram?
Discussion in 'Gen 4 Prius Audio and Electronics' started by madmax21, Feb 6, 2025.
  1. madmax21
    madmax21 Junior Member
    16
    Minneapolis
    Hi all, posted an update to my other thread but wanted to put out a new one specifically in the electronics section for this ask. Long story short, I have a 2021 steering wheel that has the heat function that I'd like to install on my 2016.
    I tested the wheel before installing and compared the clock springs. Looks like I may be missing a plug on the harness for the clockspring. Will ask here and then in a new thread - does anyone have a diagram for the electrical connections on a 2021 prius steering wheel/clockspring? Everything else connected and worked fine, so my potential thought is if I manually run a 12v and neutral to the two pins on the 2021 clockspring, I can make a diy rocker switch to feed power manually to the heated steering wheel. Guessing this way I won't have the button lit up but it'll get the warmth flowing
