2022Prius LE - No auto on lights
Discussion in 'Prime Technical Discussion' started by Tracey Flynn, Aug 21, 2021.
Tags:
  1. Tracey Flynn
    Tracey Flynn New Member
    Pasadena
    2021 Prius
    Did I really just but a $30k car with no auto on headlights? Even my 2017 prius had this!
  2. schja01
    schja01 One of very few in Chicagoland
    1,754
    1,168
    Chicagoland
    2018 Prius
    If you have it it would be on the "Turn Signal Stalk" labeled "Auto". From the quick reference guide it seems you may not have it.
  3. ChapmanF
    15,865
    I bought a 2010 for less than $30k and then added auto headlights ... I don't know whether it's as easy in a 2021, but that might be a solution. Found the stalk switch with the auto position from a recycled '09 Lexus for cheap.
    KYBlue likes this.
  4. burrito
    burrito Active Member
    274
    114
    On my 2015 Prius Two, I just leave the headlights on all the time. They turn off automatically 30 seconds after turning the car off and locking the doors.
  5. Salamander_King
    Salamander_King Senior Member
    10,975
    8,873
    New England
    No auto headlight on LE model. Toyota clipped the PP lower trim levels to differentiate from the Ltd model. Prius model has BSM and other features on lower trims that are found only in PP Ltd.
  6. KYBlue
    KYBlue Active Member
    227
    112
    Need to get the wiring info for the newer ones and give this a shot....
    Was a former car audio installer, still do remote starts for family etc. I'd love to add this to my PP LE.....
    BiomedO1 likes this.
  7. BiomedO1
    BiomedO1 Senior Member
    1,535
    823
    SacTown, Ca
    Report back what you find out. I'd like to do this mod. too. From my experiences with Honda's and Toyota's; they're usually pre-wired. May have to add a fuse and/or relay in the fuse box to activate this function.
    My last car was a 2013 Prius C One, I wanted cruise control and found out all I had to do was buy a cruise control stalk and notch out the steering column plastic. It was plug and play and save me several grand in not having to move up to the Two.
  8. Hidyho
    Hidyho Senior Member
    2,698
    529
    2018 Prius
    Toyota likes to cheap out on the parts to make different models, parts that shouldn't be cheaped out and should be across the entire line, auto headlights, under dash lights, cruise control and on and on. Things like HUD, auto wipers and stuff like that sure, but not basics.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    That also leaves the TAIL lights on all the time and makes your brake lights slightly harder to notice in the day time.
    That is why the tail lights do NOT come on in DRL mode.
  10. bisco
    49,696
    welcome
    i think it stinks...
  11. David9962000
    David9962000 Member
    139
    66
    2020 Prius
    That might work in our LE, I see we have the sensor on the dash.
    Never understood why we don't have it. We have so many other features!
