Featured 2024 Ford F-150 Lightning to Includes Vapour-Injected Heat Pump on All Models
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Oct 3, 2023.
  1. Tideland Prius
    16,445
    Why The 2024 Ford F-150 Lightning Heat Pumps Are A Big Deal
  2. PriusCamper
    PriusCamper Senior Member
    12,046
    4,889
    Pacific Northwest, USA
    I can just imagine the Toyota designers scheduling a meeting to find out what a heat pump is...
  3. hill
    8,640
    Prius Prime has one
    so does bz4x & the Subaru clone of it
  4. Trollbait
    12,344
    The gen4 PP's was also a vapor injected type too.
    I suspect we'll soon see heat pumps being standard in most BEVs. Previously, low supply meant higher cost for one, but the the supply should shift as more EVs come to market.
  5. hill
    8,640
    ..... or .... manufacturers of supplies of heat pumps may (hopefully it won't) end up like Toyota's very limited supply of traction pack battery sources. Not available for high quantities based on long-term contracts said manufacturers.
  6. bisco
    51,134
    about time, the 2023 lightning owners won't be happy
  7. Mr.Vanvandenburg
    1,327
    544
    2020 Prius Prime
    The Toyota Prime had it in 2017 and I believe it’s made by Denso. I wonder if Ford will get them from or in partnership with Denso.
  8. Trollbait
    12,344
    They'll probably be more peeved about Supercharger access.
  9. El Dobro
    El Dobro A Member
    7,075
    3,258
    Doing fine without one for the past 5 years, no biggie.
  10. hill
    8,640
    speak for your self
    i do miss the supercharger convenience - prior to selling the car ... & retiring. Driving through Santa Ana 5 days a week 4:30 a.m. & the location was right off interstate 5. Had my choice of over 2½ dozen stalls ... got off the freeway - picking up a quick 55 miles / & back on the freeway in under 15 minutes. And back in 2018 ? it was freeee! (incorporated into price i suppose)
    good times
    #10 hill, Oct 5, 2023
  11. bisco
    51,134
    if you don't use most of your range, it isn't as big an issue. but if you're trying to eek out maximum range, you'll be stopping a lot more often with resistance heat
  12. hill
    8,640
    Tideland Prius likes this.
  13. bisco
    51,134
    i thought tesla's heat pump was rated the best?
    watch
    watch
  14. Tideland Prius
    16,445
    I do not know. I thought the Toyota's vapour-injected heat pump on the Prime was pretty efficient and this was back in 2017!
  15. hill
    8,640
    Maybe Sandy Monroe will compare the 2.
  16. El Dobro
    El Dobro A Member
    7,075
    3,258
    That's why I traded my Spark EV in for another Bolt. It was fine for the distance I traveled to work, but with a job change, another Bolt works out much better. Preheating in the Winter and heated seats and steering wheel really stretch out the battery range.
    bisco, hill and PriusCamper like this.
  17. Trollbait
    12,344
    I remember it being a big deal with it being a first auto heat pump to have the vapor injection tech back then. All I know about Tesla's heat pump is that they didn't start using one until after that Prius came out.
    Using a heat pump or not, or vapor injected or older type, comes down to costs and market. A Hyundai EV(Kona?) didn't have a heat pump in the US, but did in Canada.
  18. meeder
    meeder Active Member
    239
    162
    Doesburg, The Netherlands
    The Tesla heat pump is a crazy efficient design. They can take heat from multiple sources through the octovalve. It's also extremely compact. It's also very quiet in its operation.
    I have my Model Y set to have the cabin at the desired temperature when I leave in the morning and you hardly hear it (nice for the neighbours).
  19. hill
    8,640
    But all of their newer offerings are heat pump standard in all markets - aren't they? For example the EV ionic 6 is more efficient than a Tesla. They couldn't pull something off like that using resistance Heating.
  20. rjparker
    rjparker Tu Humilde Sirviente
    9,586
    5,885
    Texas Hill Country
    Vapor injection was first widely used in some industrial applications. Mitsubishi employed it decades ago in their “hyper heat” heat pumps which can output full rated btus at 5f while conventional designs have rated btus around 47f.
    A conventional 3 ton heat pump will output 1.5 tons at 17f and typically is supplemented with expensive to operate electric strips.
    The key to a “low ambient” system is a variable speed compressor that can overspeed at low temperatures. The downside of overspeed is increased compressor heat. The compressor is kept cool in this mode by vapor (flash) injection.
    In residential applications of “hyper heat” with vapor injection, power use goes up instead of down at low ambients while noise increases.
    Mitsubishi also uses a hot gas (freeze protection) loop for defrost instead of supplementing the conditioned space with electric strip heat during defrost. Electronic expansion valves, heat exchangers for vapor injection and computer control complete the rather complex but effective low ambient strategy.
    EVs are a good application for vapor injection.
    Shown in Heat Mode without a Reversing Valve: hyperheat flash injection.jpg
    #20 rjparker, Oct 6, 2023
