Discussion in 'Gen 3 Prius Main Forum' started by Nathen Mudryk, May 17, 2019.
  1. Nathen Mudryk
    Nathen Mudryk New Member
    Fort Myers, Fl
    While sitting in front of my son’s school today, my 2011 Toyota Prius’ “check hybrid system” warning light and check engine light came on. I’m not sure why or what’s wrong. My Prius now doesn’t accelerate the way it normally does. I what should I do?
  2. spiralhelix
    spiralhelix Active Member
    255
    217
    Illinois
    take it to a local auto parts store and have them read the code for you or your other option is to drive to the dealer and have them look at it. It's possible that the hybrid battery voltages are starting to get low (maybe one or more). I'm not sure if an auto parts store will have a good enough computer to test battery voltages though, so you would need to get a bluetooth obd-II to read the battery voltages (google search as there are many options that work) . They are relatively inexpensive too, $20-40 on amazon. But from a timing standpoint, your options are store, dealer, or friend that has one.
    Good luck.
  3. Mendel Leisk
    41,822
    Do you by any chance have anything always plugged into the OBD port?
    How many miles?
  4. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Once you get the codes the people here can discuss solutions.
  5. spiralhelix
    255
    217
    Illinois
    Just curious what you mean by this? Does something plugged in have a negative impact on the car? Gawd I hope not, i had left my BT reader plugged in for like a year or two. Whoops! TBH, i kinda just forgot it was plugged in for a long time. I have had it unplugged for a couple months now and leave my other scanner in seat pocket.
  6. Mendel Leisk
    41,822
    I had a scan gauge constantly connected, and it was apparently the source of repeated HSI warnings, coupled with brake warning lights and return-to-defaults brake behaviour.
    Disconnected, problem stopped.
    Mechanic noted a loose connection while testing with Techstream at dealership (for the above problem), suggested I try disconnecting.
    spiralhelix likes this.
  7. DavidA
    2,345
    1,821
    Chicago western burbs
    +1 on the suggestion to grab the codes from from the incident. Was the inverter recall service done to the car some years back?
  8. bisco
    52,277
    clean the battery cooling intake grille
  9. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Were you sitting at the school with the car in “Ready”, or with the auxiliary battery only on?
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Similar to Rays question....any chance you had it in neutral with the AC running?
    After recording any fault codes (if possible, and if not possible, then so be it): When all else fails, put it in drive, hold foot on brake and give it a bunch of "go pedal" to force charge the battery. After a few minutes of that, disconnect the 12v battery for a minute or two then reconnect it. Start the car again. It may take two presses of the power button to clear the alarms caused by disconnecting the 12v battery. Put it in drive and see what happens.
    #10 TMR-JWAP, May 18, 2019
