22 Prius Prime - Constant/Ignition 12V Wiring
Discussion in 'Prime Audio, Electronics, and Infotainment' started by EdvinG, Jan 19, 2022.
  1. EdvinG
    EdvinG New Member
    Nova
    2022 Prius Prime
    We have a 2022 Prius Prime XLE. I installed the auto dimming mirror with homelink and compass. The only issue is I’m unsure of where to tie into for power.
    I need to find a constant 12v wire and an ignition 12v wire.
    I have attached a few photos of what I’m working with.
    I haven’t been able to find a wiring diagram for our vehicle. Appreciate your alls help!
  2. pghyndman
    pghyndman Active Member
    498
    465
    CT shoreline
    Since you are already at the rear view mirror assembly you might want to check the power source already available under the cover plate. I recently installed a Fitcamx on my 2021 Prime Limited and power was already available there. Fitcamx provided a swap out cable, but you should be able to ferret out and splice into an acceptable fused source from there, and can go directly to the HomeLink mirror from within the assembly.
  3. Mendel Leisk
    38,661
    There will be a constant on wire running to the obd port. The install instruction spec's you need constant on?
    And I think most other 12 volt wires will be ignition on, the cig lighter for example.
    You can verify with a circuit tester, a gizmo like a screw driver with a light in the handle, and a cable with alligator clamp. Clip the clamp to a ground, then probe with the tip of the screw driver. Light in handle goes on when you've got voltage.
    #3 Mendel Leisk, Jan 21, 2022
