220v Charging More Efficient?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bilofsky, Jan 17, 2013.
  1. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    A full charge off 110 at home uses about 2.90 kWh according to my WattsUp.
    Chargepoint says it gave me an almost full charge (0.6 EV miles left) for 2.42 kWh. (At the 110v rate it would have taken about 2.73 kWh.)
    Is the 220v charger more efficient, or is something else going on?
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    it`s kinda hard to repeat the same charging senareo every time so the kwh is not going to be the same every time
    M729 ? 2
    It`s a 500 watt spread
    M729 ? 2
  3. lensovet
    2,614
    496
    Burlington, NJ
    220 is supposed to be more efficient, but i'm confused, you're comparing charging from empty to charging from 0.6 miles left?
    discharge battery to the same level (and verify via scan gauge or torque) and then compare
    49,392
    i have read that 240v is more efficient. since i got my 240v charger, i hadn't charged to full at work with my original toyota evse. yesterday, i was there for a few hours and it finished charging with an ev range of 12.5 miles. at home with the 240v, it's been 12.3 for weeks now and was again today. i wonder if it is able to 'top up' a bit more with the 120v?
  5. lensovet
    2,614
    496
    Burlington, NJ
    bisco i feel like you should really invest in a scan gauge or torque
    priuskitty likes this.
  6. bisco
    49,392
    agreed. i was waiting for peef to complete his custom job but it looks like it's not gonna happen. i should probably grab one on amazon. i'm not a tech like you guys tho, i hope i can figure it out!(n)
  7. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    You're not confused, you're calling me on sloppiness. :)
    Even accounting for the difference, 220 was still 12% more efficient. And I've seen the same thing charging on 220 from empty: it's in the 2.5 - 2.6 kWh range. Plenty enough to see there's a difference, although not to quantify it precisely.
    What parameter do I look for on a ScanGauge (or in my case on Torque)?
  8. lensovet
    2,614
    496
    Burlington, NJ
    Battery SOC? to make sure that the starting SOC is similar in both cases
    wait what happened with you and peef?
  9. bisco
    49,392
    he had started a thread showing his version of scangauge. (it's in here somewhere) it was a hundred times better and he was going to start producing and selling them. but then he got involved with leaf and left pchat and i guess got too busy to follow thru.
  10. lensovet
    2,614
    496
    Burlington, NJ
    oh i thought you were talking about a custom charger. now looking back i can see that you were replying to my post saying you should get a monitoring device.
  11. bisco
    49,392
    sorry about that.:oops:
  12. hill
    8,158
    #1 - It's actually more accurate to refer to L2 as 240V. That's why you'll get a reading like you see on my Fluke below, if/when you measure the power from your service panel out to your EVSE:
    #2 - I recall the OP being asked & answered at least 2x on the board, and yes ... 240V charging is at least 10% more efficient than 120v charging. Or if you look at it from the other side, yes, you're wasting power when you charge L1.
    Totmacher likes this.
  13. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Thank you. My measurements show it 10.6% more efficient, based on Chargepoint and Watts Up kWh figures.
    I searched really hard before posting (as I always do) and did not find the other answers.
  14. greenleaf
    greenleaf Member
    153
    35
    Silicon Valley, CA
    If I recall correctly, there is some overhead during charging. This overhead (e.g. running the fan) does not go into charging the battery.
    The overhead is a smaller fraction at 240V than at 120V, so charging efficiency is higher.
  15. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Interesting. Anyone know how much overhead?
    The battery takes less power in cold weather than warm weather. Wonder how much of that is due to more cooling needed when it's warm.
  16. 3PriusMike
    2,963
    2,314
    Silicon Valley
    Yes, see my post here:
    Charging efficiency of PIP | PriusChat
    I measured about 9% losses ~26.5 kwh used, 29.1 kwh charged...over 7 days and 132 miles on EV.
    Mike
  17. Totmacher
    Totmacher Honey Badger don't give a carp
    301
    110
    Mission Viejo, CA
    Isn't this basic electrical theory...
  18. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    200v inverter/chargers are always more efficient than 100v inverter/chargers.
    Stepping down the voltage loses a few % more. Stepping up the voltage isn't considered an efficient design practice if a higher voltage is already available. 1 to 1 (or near) conversion with a small step-down is the best.
    In order to push electrons into the battery they need to be subjected to a high voltage than those already in the pack. Since the PiP battery and charger were designed to be 200v systems this is the voltage where they are most efficient.
    This applies to series strings PV panels and to PV microinverters as well. Each unit will have a slightly higher voltage as you go away from grid or charge controller load. http://enphase.com/wp-uploads/enphase.com/2011/12/EnphaseTechBrief_Vdrop_M215.pdf
    Some examples of high quality inverter dc/ac and double converter ac/dc/ac devices usable for Prius generator conversion. Looks like APC is the only game in town using 208v nominal 280v Max input models. And yes they have other models that will convert 200v 50hz to 120v or 208v 60 hz and 100v 50hz to 120v 60hz if you must. http://www.apcmedia.com/salestools/SCON-8UHJUH_R0_EN.pdf
    Efficiency
    Models with 120 V Output / 120 V Input(90 -150 V)
    Model SKU Efficiency
    @ full load
    APC Smart-UPS RT 1500 VA Rack/Tower 120 V SURTA1500RMXL2U 89.0%
    APC Smart-UPS RT 1500 VA 120 V SURTA1500XL 89.1%
    APC Smart-UPS RT 2200 VA RM 120 V SURTA2200RMXL2U 89.1%
    APC Smart-UPS RT 2200 VA 120 V SURTA2200XL 89.1%
    APC Smart-UPS RT 3000 VA Rack/Tower 120 V SURTA3000RMXL3U 85.7%
    APC Smart-UPS RT 3000 VA 120 V SURTA3000XL 85.7%
    Models with 120 V, 208 V Output( 120 V, 208 V, 220 V, 240 V) / 208 V Input(160 – 280 V)
    @ full load
    APC Smart-UPS RT 3000 VA 208 V with 208 V to 120 V
    Step-Down Transformer SURTD3000XLT-1TF3 92.0%
    APC Smart-UPS RT 3000 VA Rack-Mount 208 V with 208 V to
    120 V Step-Down Transformer SURTD3KRMXL3U-TF5 92.0%
    APC Smart-UPS RT 5000 VA 208 V to 208/120 V SURTD5000RMXLP3U 90.0%
    APC Smart-UPS RT Rack/Tower 5000 VA 208 V with 208 V to
    120 V Step-Down Transformer SURTD5000XLT-1TF3 91.0%
    APC Smart-UPS RT Rack/Tower 6000 VA 208 V with 208 V to
    120 V Step-Down Transformer SURT6000XLT-1TF3 92.0%
    APC Smart-UPS RT 6 kVA RM 208 V with 208 V to 120 V 2 U
    Step-Down Transformer SURT6KRMXL3U-TF5 92.0%
    APC Smart-UPS RT 6000 VA RM 208 V to 208/120 V SURTD6000RMXLP3U 90.0%
    Models with 208 V Output (208 V, 220 V, 240 V / 208 V Input var. (160 – 280 V)(156 - 236 V)(160 – 280 V)
    @ Full Load
    APC Smart-UPS RT 3000 VA Rack Tower 208 V SURTD3000RMXLT3U 92.0%
    APC Smart-UPS RT 3000 VA 208 V SURTD3000XLT 92.0%
    APC Smart-UPS RT 5000 VA Rack Tower 208 V SURTD5000RMXLT3U 91.0%
    APC Smart-UPS RT 5000 VA 208 V SURTD5000XLT 91.1%
    APC Smart-UPS RT 6000 VA Rack/Tower 208 V SURT6000RMXLT3U 92.0%
    APC Smart-UPS RT 6000 VA 208 V SURT6000XLT 92.0%
    APC Smart-UPS RT 8000 VA Rack/Tower 208 V SURT8000RMXLT6U 93.0%
    APC Smart-UPS RT 8000 VA 208 V SURT8000XLT 93.0%
    APC Smart-UPS RT 10,000 VA Rack Tower 208 V SURT10000RMXLT6U 92.0%
    APC Smart-UPS RT 10,000 VA 208 V SURT10000XLT 92.0%
    APC Smart-UPS RT 15 kVA RM 208 V SURT15KRMXLT 94.0%
    APC Smart-UPS RT 20 kVA RM 208 V SURT20KRMXLT 94.0%
  19. Totmacher
    301
    110
    Mission Viejo, CA
    Vulchers fly over the Rabbits and the Indians. Class dismissed.
  20. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    I hooked up my kill-a-watt in the garage and reset my Trip B and EV Driving Ratio 2. I'll be comparing kill-a-watt reported vs. PiP displayed kWh, to calculate the charging loss.
    3PriusMike likes this.
