220V Prius Prime Charging Cable
Discussion in 'Prime Main Forum (2017-2022)' started by Navy Chief, Dec 7, 2016.
  1. Navy Chief
    Navy Chief New Member
    San Juan Capistrano
    I just purchased a Prime. It came with a 110 volt charging cable. The manual refers to charge time with 110 and 220 cables. I called Toyota of Orange and asked about a 220 volt charge cable. I was told Toyota did not make a 220 cable. I find that difficult to believe. Has anyone heard differently?
  2. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    They didn't for the Prius Plug-in in nor the Toyota RAV4 EV, so I wouldn't expect them to make one for the Prius Prime. There are plenty of options for L2 chargers nowadays, as the J1772 plug is a well established standard.
    I would recommend the Chargepoint Home if you would like a WiFi enabled option:
    https://www.amazon.com/gp/aw/d/B0124KHJZ2/?th=1&psc=1
    This is a good alternative if you need a portable L2 charger:
    https://www.amazon.com/gp/aw/d/B00J8O1XQE/
    jmarkd7 likes this.
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    Look up evr-green mini.
    49,492
    congrats and welcome! the dealer is correct. the charger inside the car will accept both 120v and 240v, but toyota only supplies a 120v cable. it's more common for people to already have a 120v outlet available, and it keeps the cost down for buyers who have no interest in 240v charging.
    you can hacve the cable converted to a dual voltage unit for a few hundred dollars if you desire.
    all the best with your new prime!(y)
  5. Trollbait
    11,561
    Only Tesla has their own level 2/220V home "charger"/EVSE unit. Everybody else directs you to one of the many third party units available.
  6. MNdriver
    MNdriver Senior Member
    549
    577
    I have a naive question. I need to negotiate charging my [future] Prius Prime in the shared garage of my condo building. Does the charger store and display how much electricity has been used? I'm wondering if I'd be able to use to to figure out how to reimburse my condo association for charging.
  7. bisco
    49,492
    no, but you can buy an inexpensive meter that plugs into the wall, and you plug into it. it will do what you need for about $25.
    MNdriver likes this.
  8. Pedal Logic
    Pedal Logic Active Member
    163
    175
    Hi MNdriver,
    One solution would be to add up your mileage as you go and divide by the Prime's miles/kWh rating. This would give you the actual kWh consumed by your vehicle. Might add an extra 10% to that number to account for the differences between real-world mileage and what Toyota self-reports to the EPA. Even after all that, you would still have to have a cool association board. GL!
    Marc
  9. MNdriver
    549
    577
    Thanks! I have not yet broached the topic with my condo board. Hoping to find a solution that they will be happy with.
  10. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    Living in Minnesota, you have a great resource available to you.
    Check out the website... MN PEV Owners
    Look up on Facebook... MNPEVOC
    That's the plug-in owners group here (I'm in Minnesota and attend all the meetings) who have been working hard to help establish plugging infrastructure. There is much wisdom to share about the what & how for getting shared charging-stations installed.
    jmarkd7 likes this.
  11. PriusC_Commuter
    914
    307
    2014 Prius Plug-in
    You would need to get a WiFi enabled charger (technically EVSE) that has this type of capability. I believe the Chargepoint Home does (but I don't know how it deals with sharing the usage info with others):
    Home EV Charging Station for Electric Car - ChargePoint
  12. MNdriver
    549
    577
    Yep, thanks John, I'm part of the Facebook group already, and I went to a lunchtime meeting this past summer about EVs in multiple family dwellings. Haven't been too vocal in it because I don't have a plug-in - yet! Hope to rectify that very soon.
    Merged
    Just looked into this a bit. Yikes, this is going to get expensive. I hope the simple meter bisco mentioned will be acceptable with the condo board, although I have my doubts.
  13. bisco
    49,492
    check out the kill a watt meter. theft might be an issue though.
  14. MikeDee
    MikeDee Senior Member
    1,550
    590
    San Francisco Bay Area
    These seem overpriced. What about the Siemens VC30GRYU Versicharge 30-Amp Electric Vehicle Charger with Flexible Indoor/Outdoor and 20-Feet Cord? I think I'll get one before the end of the year to get the tax break.
    #14 MikeDee, Dec 9, 2016
  15. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    I think it true that a 30% tax credit that covers the EVSE and electrician is available through 2016 if UL listed equipment is bought.
  16. MikeDee
    1,550
    590
    How long is the 110v charge cable that comes with the car? Any issue with using an extension cord if it isn't long enough?
  17. Lee Jay
    5,850
    4,024
    I think it's 24 feet. The OM says no to extension cords. As an EE, I say yes to properly-rated extension cords. GFCI-protected, either by the breaker, the outlet or the cord, and 12AWG.
  18. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    Just for clarity--
    It takes an EVSE, Electric Vehicle Supply Equipment, also called a Charging Station. The 240 volt EVSE is Level 2. (120 volt EVSE is Level 1).
    1)The charger is inside every electric car.
    2) The EVSE is a smart controller that communicates with the car's charger and decides when to slow down the flow of electricity and when to shut it off.
    3) Some EVSE controllers are a box on the wall. Some are a box built into the cord (as we have with the stock charge cord).
    4) The 240 volt Level 2 EVSE will charge much faster than the 120 volt version, but where's the payback? It'll cost $300 to $500 or more plus the cost of the electrical installation. The Prime only goes 20+ miles on a full battery, then it'll use gasoline, anyway. And, it just sips the gas.
  19. ttait
    ttait Active Member
    273
    163
    Southern California
    I'm looking at the Duosida level 2 cable. The advantage for me is the quick charge time. If I come home between errands, a level 2 charger will get me enough power for short trips in a reasonable time. The meter spins the same for both level 1 or level 2, the advantage is time. I've actually found them on Ali-baba (the Chinese amazon) for under $140 not including shipping. These are the same EVSEs that are sold on ebay and amazon. I haven't bitten the bullet yet because I don't know the cost for shipping or how long it takes to get. Probably will soon, though. I have the skills to install the outlet.
  20. MikeDee
    1,550
    590
    I wouldn't use anything that's not UL (or equivalent) rated.
    iPhone ? Pro
