230k miles; never changed suspension. Should I bother?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SRQ, Feb 20, 2022.
  1. SRQ
    SRQ Member
    158
    56
    As the title states, I've never changed my suspension and think it may be time to do so. The rubber boots are basically gone, but I haven't really felt the need to replace the suspension as the ride quality is satisfactory to me and the car doesn't bounce. Will there be a cosmic difference in ride quality if I do it? Otherwise I think I'm just bored with the car and wanting to have a "project" on it lol. Everything else on the car has been meticulously maintained at proper intervals (oil, both coolants, transaxle fluid, tires, etc.) and I'm confident the car will easily last another 170k.
  2. JC91006
    16,827
    8,600
    SRQ likes this.
  3. SRQ
    SRQ Member
    158
    56
    Awesome! Have any recommendations for rear strut brand?
  4. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    KYB, they supplied the OE ones.
    JeffD
  5. JC91006
    16,827
    8,600
    When I did mine, I used original Toyota parts for the rear, they were fairly inexpensive compared to the front ones. The rear shock is $61.xx at my local dealership right now (online pricing). This is just the shock price, it is not a complete unit like the deal Rockauto has on the front assembly. Another quality option, I think the KYB brand rides similar to OEM Toyota, but just a bit stiffer.
  6. Pdaddy
    Pdaddy Member
    160
    49
    Ive replaced in gen2 and 3 and none of the decently priced suspension parts will give the same ride as OEM. If the ride seems decent and the wheels are staying on the ground I would just leave the OEM on unless you drive on really rough roads. My real impetus was ruining decent tires from when out suspension but we have decent roads here and I think j I should have waited as the replacements are not as good.
    SM-G960U ?
  7. Samuraidog
    Samuraidog Junior Member
    51
    Detroit, MI
    I'm not familiar with AC Delco strut kits. What is the quality of the ride and how reliable are they? (How long should they last?)
    Also, how do they compare to the KYB?
  8. JC91006
    16,827
    8,600
    I put a set of the AC delco ones on my car, they are very close to the oem ride. Since these are a brand name oem manufacturer product, I would think these will be very durable.
  9. mr_guy_mann
    mr_guy_mann Senior Member
    4,089
    1,997
    NJ-USA
    I don't know the Delco kits in particular- but at that price I would expect that they are made at the same factory in China that makes the "all in one" strut kits for other AM brands. I usually see decent quailty (ie, expect a 2-3 years), but it's not OE.
    Then again, sourcing struts, springs, jounce bumpers, and strut mounts from the dealer for a 15 year old car can often come close to or exceed the car's value.
    Really, first thing I would do is have the suspension inspected. Check for looseness, worn bushings, irregular tire wear, ride height, leaks, damper function, etc. Then figure out what you need to replace and go from there.
  10. jdenenberg
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    KYB struts come with a lifetime warranty. What is the warranty on the Delco struts?
    JeffD
  11. JC91006
    16,827
    8,600
    The professional Delco ones are on closeout, they don’t retail for that price, more like $150+ each
  12. JC91006
    16,827
    8,600
    I’m curious if anybody has ever claimed warranty on these things, after 10 years, most would throw them out
  13. jdenenberg
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My KYB struts that were installed at 150k miles were still OK at 288k miles when I traded in my 2004 Prius for my 2017 Prius. Since they were still working, I couldn't exercise the warranty. ;)
    JeffD
  14. JC91006
    16,827
    8,600
    I think parts like these are hard to claim. Most people would buy new parts and have them ready before removing the old parts. With a warranty product, you need to remove the part and then go do a warranty claim. The downtime makes it difficult to claim.
    But of course a quality part will last much longer than one of inferior quality. That’s why we own Toyota cars
  15. ColoradoBoo
    ColoradoBoo Senior Member
    1,271
    879
    Monument, Colorado USA
    The 10-year mark is where I normally start replacing or, at least, inspecting a bunch of stuff for possible replacement including suspension parts. My daughter has a 2012 Sienna that I've been doing this on...boy new parts are NOT cheap!
    But be aware that those nuts and bolts in suspensions are one of the most rusted areas so a simple 1-hour job could easily turn into an all-day nightmare! (Ask me how I know!)
  16. JahT
    JahT Member
    145
    77
    What about replacing the A-Arms? The stealership told us that the A-Arms needed replacing as the bushings were shot, but if there were no bushings I should hear some clunking and I don't. I think I have all original suspension on our 2008 with 193k miles. It seems to still have a good ride. When the time comes I assume I should replace strut assemblies and A-Arms all at once, is that correct? What else would be on the "while you're in there" list? CVs?
  17. JC91006
    16,827
    8,600
    Control arms don’t need replacement unless bushings are bad. You don’t want to change out something that is not broken.
    New control arms won’t necessarily be better, those rubber bushings can be really poor quality if the replacements are not OEM
    JahT likes this.
  18. mr_guy_mann
    4,089
    1,997
    NJ-USA
    Depends. Sometimes the control arm bushings can tear and allow excessive movement without making much noise (ie, there's no metal to metal contact yet).
