244k miles. . . Replace battery or say goodbye?
Discussion in 'Gen 2 Prius Main Forum' started by Anitra Montgomery, Oct 31, 2020.
  1. Anitra Montgomery
    Anitra Montgomery New Member
    Nashville TN
    Four Touring
    I've had my 05 since 2014 and she's been great! Last Dec she lost power and i could hear a loud rattling noise. So i had her towed home where she's been sitting ever since (i know, i know). Had her towed to the mechanic yesterday, finally. And he tells me the hybrid battery needs replacing ($2500) and then he'll be able to figure out the transmission/rattling issue.
    Is it worth it with 244k miles? Any other options?ANY solid advice?
    Also, ive used him before and i do trust his work. Just reaching out for some experienced Prius wisdom
  2. PriusHead05
    PriusHead05 Member
    318
    Not worth it. If you need a new transmission, one from Toyota (part only) costs about $4,000.
  3. PriusCamper
    PriusCamper Senior Member
    13,094
    5,309
    Pacific Northwest, USA
    The error codes for battery problems will sometimes raise concerns about anomolous transmisison error codes, but they almost always go away once battery problem is resolved.
    Gen 1 had a problem with bad stators in its transmisison but I've seen almost zero transmission problems on Prius in Gen2 and Gen3...
  4. PriusCamper
    13,094
    5,309
    It only takes 2 hours to replace a battery pack with a new one that can be found from some dealerships for as low as $1600...
    So your mechanic is clearly not familiar with this type of work... When an experienced mechanic sees error code that says: "PA080 - Replace Hybrid Battery" they know that's just a primary code that doesn't identify the problem and you need to get the subcodes.
    One of the most common problems I see with PA080 is a failed voltage sensor harness... It's a $50 part and 2 hours of labor to repair. I've also seen subcodes of PA080 that point to corrosion in the cooling fan circuit, which can be fixed in 5 minutes.
    In other words, there's lots of different problems that this error code may be referring to and you need to find someone who can help you sort it out for lowest cost possible...
  5. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Any rust issues?
    If there is, time to let it go.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    A 2005 with 244k miles and the original HV battery that has been sitting unused and un-started since December of 2019.
    The 12v battery is dead.
    The HV battery, at an absolute minimum, has multiple discharged modules causing HV Battery failure codes. The HV battery was apparently working up to the moment of the initial 'rattle/loss of power' failure occurred. Whether this failure was caused by the battery or something else is a guess, as any stored codes are long lost. A loud rattling noise and loss of power could be as simple as a failed spark plug or ignition coil.
    The HV battery can be replaced cheaply by any of the many $500 craigslist 'specialists'. Longevity is questionable, but it would at least get you going.
    I think we also have a few members in the Nashville area that may be able to chime in with some more local advice.
    Isaac Zachary likes this.
  7. Anitra Montgomery
    Nashville TN
    Four Touring
    The mechanic said he wasn't able to get a reading because the car only stays on for a min. Should I replace the 12v first or try to find a replacement hv battery? Also he's pretty sure there is a transmission issue
  8. PriusCamper
    13,094
    5,309
    Ideally you'd want to get someone who has a spare 12v and spare hybrid battery and put those in and start the diagnosis of what else it needs that way. I'd be wary of putting any money into it until you know what it needs. Quite often a new 12v, an engine tune up and hybrid battery clean up inspection & reconditioning is all you're going to need.
    Has the mechanic worked on hybrid cars? Because there's a few things said that are common misunderstandings: 1) the car only staying on briefly is often simply the hybrid battery spinning the engine and it never starting, 2) the transmission problem could simply mean that the computers detected a problem with hybrid system and shut down all functions of the transmission other than going into neutral. 3) the error codes that you need are specific to Toyota Prius and most generic code readers that mechanics use don't get these subcodes.
  9. Eric34
    Eric34 New Member
    Sacramento
    You can find a replacement battery for less than $1000 You can install it yourself otherwise it is another $250. I Just installed a Highbrid battery At 244 k for my 2014 Prius. I put in a new 12 v battery too since it was already 5 years old and getting weak.
  10. dolj
    dolj Senior Member
    8,567
    4,353
    Wellington, New Zealand
    You can't find a brand new battery for less than $1000, they are all second-hand and real value is very much a crap-shoot.
    However, a second-hand battery might do for now.
    If the car really has 'transmission issues' (and what makes him think it is 'transmission issues') it would be a better idea focussing on that.
    kenoarto likes this.
  11. Anitra Montgomery
    Nashville TN
    Four Touring
    Thank you. He did hear a noise once he got the car started but the car only stayed on for a min so he couldn't inspect.
    I am getting her towed by a certified hybrid technician/ mechanic. They are able to test the battery itself. . I'll keep you posted!
    #11 Anitra Montgomery, Nov 8, 2020
    PriusCamper likes this.
  12. Anitra Montgomery
    Nashville TN
    Four Touring
    So the new mechanic was able to start the car. It "definitely threw a rod" so the motor will need to be replaced. They are in the process of testing the hybrid battery to determine if its the whole battery or just certain cells.
  13. bisco
    52,409
    it's never the whole battery, but replacing cells is like whack a mole. figure the cost of a new battery and motor, or salvage if you can find decent ones, and compare to purchasing something newer with lower miles
    Aaron Vitolins likes this.
  14. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    You're looking at 5k for an engine and new battery. Probably 3000-3500 for an engine and used/rebuilt battery. It's hard to justify it.
  15. Anitra Montgomery
    Nashville TN
    Four Touring
    So we would need to replace the motor and hv battery. But the mechanic is having issues finding "used" for either. They are wanting to go through their suppliers which offer a warranty and have been tested. And while i understand and appreciate that, im wondering if there are other options for acquiring the battery and motor. You're help/advice would be most appreciated
  16. mr_guy_mann
    mr_guy_mann Senior Member
    4,098
    2,000
    NJ-USA
    Another option is google and some phone work. Find a "parts recycler" (aka junkyard) who can get what you need and that can deliver to your shop. Talk to you mechanic about this before you do it- some places won't deal with customer supplied parts. Just realize if you get the parts, the shop will not warranty anything if the part is bad.
    Anitra Montgomery likes this.
  17. PriusCamper
    13,094
    5,309
    Don't worry too much about the HV battery, even if folks on here want you to worry and think you need a new one, it probably just needs charging/easy task for yr mechanic or nearby person on priuschat.
    Finding an engine for your car is not something most of us on here would ask our mechanic to do. Rather, we'd figure out how to find the best engine possible and have it delivered to the mechanic. Also if you have the mechanics biz info you may be able to get wholesale price delivered to them, which at times for me for other major parts has meant 1/2 price.
    #17 PriusCamper, Dec 3, 2020
  18. Anitra Montgomery
    Nashville TN
    Four Touring
    I am definitely a "thrifty" shopper" in all other area of my life but realize Ive been spoiled because my uncle has always taken care of any serious mechanical needs. But I live out of state (from him) so this is a bit overwhelming. I did do a quick search on ebay and was confused why the mechanic couldn't find a replacement when i found several on there and for WAY cheaper than they were quoting even with a mechanic mark up. But I have no idea what im looking at and should be looking for.
    I'll check to see if they even accept customer supplied parts first. Then I've gotta hit the ground running to acquire the motor.
  19. PriusCamper
    13,094
    5,309
    There's lots of engines out there... Your mechanic is just not finding them from the people he usually buys from. And if I were you I'd get in touch with your uncle. He'll be of great help with finding you an engine. And due to the amount of labor involved in an engine swap it might be less expensive to have the engine and car shipped to him. If he's done car work for the family for a long time, he probably has lots of ways to help cut costs.
  20. qmanqman
    qmanqman Active Member
    439
    152
    CO
    No reason to put another new engine into a car that you can replace with another car for less. Hell you can get an 07-09 for $2500-3000.
    Plus, if it threw a rod that tells me you don't really maintain your cars very well. Routine oil changes would have kept this from happening. Just get another car and drive it into the ground.
