Featured 25km of hydrogen pipeline constructed in China
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by usbseawolf2000, Nov 14, 2015.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    The pipeline, with a diameter of 508mm and a distance of 25km, starts at the hydrogen generation station at the Jiyuan Industrial Park and ends at Luoyang Petrochem complex in the Jili district.
    The working pressure of the pipeline is 4 MPa, and it is capable of delivering more than 10,000 tonens of hydrogen every year.
    The company also noted that due to the mountainous and steep geography along the route of the pipeline, many obstacles have to be overcome, including the need for tunnelling and crossing railway lines and highways.
    25km of hydrogen pipeline constructed in China | News | gasworld
    The article did not say how they got around the problem of hydrogen embrittlement. Perhaps, they just painted to separate hydrogen frim the metal pipe.
  2. austingreen
    austingreen Senior Member
    13,574
    4,114
    Austin, TX, USA
    There is no technical problem of building new hydrogen pipelines, they simply require more expensive materials and inspections than natural gas pipelines. This means a high quality stainless steel. This starts out more brittle than carbon steel they use on natural gas pipelines, but as the chromium in the steel oxidizes it forms a protective layer, preventing the hydrogen from attacking the carbon in the steel. Still like any pipeline stuff happens so they need period inspections and replacement. At the same pressure a hydrogen pipeline needs a crossesectional area three times bigger to carry the same energy content of gas. That is why the diameter of this pipe is so big. Higher pressure allows a smaller pipe, but then materials get more expensive like carbon fiber, and maintenance is even higher. This is specified at 4 Mpa, or 40 bar, much lower than the 700 bar fueling stations compress up to, so the staion would probably have a low and high pressure tank.
    Given the high cost of the pipelines, trucking hydrogen is often much less expensive unless you are close and have high volume.
  3. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    It doesn't sound as bad/expensive as you put it.
    Widely used model suggests 10% more cost but realistically, it could be up to 60% more depending on the diameter.
    But then the code is very old and an update is in progress.
    Existing codes for hydrogen pipelines are based on decades-old data. NIST researchers are studying hydrogen’s effects on steel to find ways to reduce pipeline costs without compromising safety or performance.
    As an example, the new code would allow a 24-inch (61 cm) pipe made of high-strength X70 steel to be manufactured with a thickness of 0.375 inches (9.52 mm) for transporting hydrogen gas at 1500 psi (10.3 MPa). (In line with industry practice, ASME pipeline standards are expressed in customary units.)
    According to the new NIST study, this would reduce costs by 31% compared to the baseline X52 steel with a thickness of 0.562 inches (14.3 mm), as required by the current code.
    In addition, thanks to its higher strength, X70 would make it possible to safely transport hydrogen through bigger pipelines at higher pressure—36-inch (91-centimeter) diameter pipe to transport hydrogen at 1500 psi—than is allowed with X52, enabling transport and storage of greater fuel volumes. This diameter-pressure combination is not possible under the current code.
    NIST Calculates High Cost of Hydrogen Pipelines, Shows How to Reduce It
    Perhaps you are trying to inject FUD but it does not make sense.
    To transport a large amount of anything over a long distance, pipeline is better than trucking.
    With the updated code, H2 infrastructure can be 10-31% more expensive than natural gas infrastructure. Even the NG pipes can/should be upgraded to handle H2.
    The fear, uncertainty and doubt you have injected into some of the minds here is more dangerous than H2 itself.
  4. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    There's a lot of oil being transported through this area via train. A pipeline would be more efficient. But then again, why bother building one for an energy-carrier not able to be renewable based?
    austingreen likes this.
  5. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    Exactly, which is why H2 pipe that could be producted by renewable and stored is a great investment. It can potentially replace fossil (NG and Oil) pipelines.
  6. austingreen
    13,574
    4,114
    Austin, TX, USA
    I did not say it was bad, I was trying to just put out the facts. The diameter needs to be 1.7x larger for the same volume of energy. I know in order to save costs many pipelines have skimped on material, but that is true to of natural gas and oil. Material should be much higher, but IIRC it is thinner, and I don't think labor needs to cost that much more. If stainless was so cheap it would be used more.
    The number I have heard is around 70% more expensive than natural gas.
    sure in a refinery runs are short and volumes high, it makes sense to build infrastructure. If you are building stations that only dispens a few hundred kg of hydrogen a day, you will never pay for it. This Chinese pipe is a much higher volume and a short run, only 25 km.
    If you are talking about lowering the cost of hydrogen, building expensive pipelines won't help, unless its in a very dense city with high throughput (millions of fcv) of hydrogen.
    Like I said, I just am reporting facts. you are acting as if facts are your enemy. Your link says 68%, I've heard and said 70%, let's go with your number of 68% from your link. That is for short distances. Long distance is just tough with hydrogen. No one builds 100 mile pipes, and trucking it long distance is pretty bad too, you want to liquify and keep it cold, on truck or ship if you are going more than 20 miles.
    Now you have an article that is really new informationto me, that instead of preventing accidents like this NIST wants to lower standards. Maybe it will work. idk.Maybe thinner walls higher strength more inspections.
    CSB Releases Analysis Showing Cause of Rupture and Hydrogen Blast in 2009 Silver Eagle Refinery Accident in Woods Cross, Utah; Pipe Walls Thinned due to Corrosion that went Uninspected for Years - General News - News | the U.S. Chemical Safety Board
    If they change the law, they can make it cheaper. I don't know why they would not also make natural gas cheaper by lowering those standards, but, anyway. No fight in me against newer standards as long as they up the inspections to reduce accidents.
    Again your pricing is based on building infrastructure and lowering standards for pipelines. I don't think you can really accuse me of FUD. Your argument is based on a hypothetical law change.
    If you had instead said, there is a X percent chance that california moves money from building hydrogen stations, to building hydrogen pipelines, and changed the law to make it cheaper to make pipelines, I would have simply said that is unlikely to work out.
    #6 austingreen, Nov 14, 2015
  7. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Nonsense. What's dangerous is the unwavering insistence that this pipe dream of hydrogen is somehow going to lead us to health and prosperity. It's not. Seeing your flag-waving meeting with some resistance does not surprise me in the least.
    finman, Trollbait and austingreen like this.
  8. Trollbait
    11,560
    This pipeline is being built to feed a petrochemical plant. Petroleum refining and other industrial processes require hydrogen. Building short pipeline between plants to transport this hydrogen isn't a new idea. There is over a 1000 miles of such pipeline already in the US. One or two of California's hydrogen stations might tap into such pipeline.
    Nearly everything can be cheaper if you are willing to trade off safety. Perhaps newer materials can lower costs without that trade off. Even with those savings, it will still cost billions to supply a nationwide network of hydrogen stations for cars. Converting NG lines doesn't sound like it will save much, because they will carry less energy with hydrogen than they did with NG, and now you have to transport that NG somehow. People with gas stoves aren't going to be happy with hydrogen.
  9. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    By the nature of the technology, FC stack is more efficient (~60%) at extracting energy from hydrogen than say a combustion NG engine that is in Civic (~30%). You'll need to look at the end result, not just the volume of energy a particular pipe can move.
    To move the same amount of energy in the form of electricity, you are going to need very thick copper wires.
    If you were reporting facts, where was the reference? Here is what you said:
    This is false as my link said the more expensive X70 high strength steel can have H2 pressure of 1500 psi (10.3 MPa). The pipe that Chinese used transports at 4 MPa. You don't need carbon fiber once the code is updated.
    They are not lowering the standards.
    The code modifications, which NIST has proposed to the American Society of Mechanical Engineers (ASME), would not lower pipeline performance or safety, the NIST authors say.
    The code was also outdated so they are adding a new type of steel that can handle higher pressure.
    You came off really anti-hydrogen. It appears, in your mind, it will cost a lot of money to build hydrogen infrastructure. It turns out, it is not much different than natural gas.
    In fact, H2 infrastructure may be a hybrid between oil and natural gas. H2 production pipeline will only distribute to H2 pumps/stations. FCV would go fill up there, go home and power the house with the "plug out" feature.
  10. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    Health and prosperity? I've never made such claims.
    I have said, FCVs will help us (together with BEVs) achieve energy independence. The reason is, both technologies are fossil fuel independent.
    I have also said, FCVs can start off powering from domestic fuel (natural gas) or renewable as California H2 requires 30% from renewable.
    FCVs also has zero tailpipe emission like BEVs, so it'll be good for cities.
    I am against PHEVs getting the same amount of incentives as BEVs. It is not right that FCVs get zero federal tax credit while Volt with 37 MPG gas engine got $7,500 tax credit.
    China is constructing hydrogen pipelines. I have not seen any news in the US of constructing new H2 pipelines. As the code gets updated, we should see more soon, I guess.
    Is it a pipe dream? We'll see about that. I am convinced that it is a good technology that can change the world. Cities will look different (less power lines), cleaner (emission), runs on stored renewable energy, etc. Battery can help us achieve some of those but not at a scale we need to make an impact.
    Where can I find such information?
  11. hill
    8,183
    "could-be" doesn't mean reality. Look at a lot of the stuff in china. Quality is better, but a long way to go. For china, "could be" and "what's cheapest" collide. The reality of coal & natural gas is that it's cheapest, so why talk "could be" ??
  12. austingreen
    13,574
    4,114
    Austin, TX, USA
    Oh I'm sure we wouldn't be building natural gas lines to power civics. They are there for heat and electricity. You need the same energy in the gas to cook food or heat a building. We don't build oil pipelines to gas stations they dimply are too expensive.
    sure you need think cables. They are much less expensive per unit energy than natural gas pipelines, which are much less than hydrogen pipelines. What is your point. Do you think people don't want lights in their homes, or tv, or internet. We have built the grid. Still improvements are needed. Natural gas doen't go everywhere yet with about 300,000 miles. and hydrogen pipelines are much more expensive and have about 1000 miles of hydrrogen pipeline in the us.
    EIA - Natural Gas Pipeline Network - Transporting Natural Gas in the United States
    Your all over the place. Yes your link has 4 MPa, which is a little less than 600 psi. That is low presure. Then your other link said that hydrogen cost 68% more than natural gas, prettey much like I said. I really don't know of any move to change the standards. If that was your point that you think standards need to drop, you should have done that, instead of jumping up and down like a monkey, yelling that I don't understand and am lying because I don't understand that you are talking about some strange legislation that I haven't read. Is it even before the regulating bodies?
    That is thinner and cheaper that is called lowering standards. Nothing wrong if it is safe enough but makeing the standard for thinner pipes is lowering the standard for pipe thinkness. It really is not hard to understand. People can us better grades of steel today. We do have pipeline leaks with today's standards. Most of the problems stem from lack of inspections as the pipes get too thin. you can build them thinner and replace the more often. I don't know. I don't build pipelines.
    about 68% more expensive than natural gas, which is a lot more than trucking the hydrogen. Yes I say that is a lot.
    Well you know if it is so cheap do it, build it. What I hear is people want to raise taxes to build it. If it is cheap and easy and profitable, I'm perfectly happy with you, or linde, or toyota building pipelines to your hearts content.
    If you are asking to raise taxes to build it though, and claim its realy really inexpnsive, less than current infrastructure, my question is why you want my tax money to pay for it?
  13. Trollbait
    11,560
    The increase in efficiency of a fuel cell isn't enough to account for the energy lost to hydrogen's lower btu's, and powering cars is a minor part of what natural gas is used for. Heating and cooking depend upon those raw btu values coming out of the nozzle. Then there is the safety aspect. Hydrogen range tops will have a near invisible flame, and the gas is odorless. Fuel cells need pure hydrogen. So the simple leak detection method of an odorant is out of the question. which means all those homes and businesses using natural gas now need hydrogen detectors installed.
    That sounds like work for no benefit. How about we take all the homes off the grid, and make every one use a generator? Sounds silly right, but at least the house is only without power when the generator is out of fuel, and not because the car had to go somewhere.
    China is building new hydrogen pipelines to supply new factories and refineries that are with a hundred miles or less of the hydrogen generations site, which is likely reforming natural gas or coal. FCEVs or even stationary fuel cells have no part into why they are building them.
    There really isn't much of a need for new ones in the US.
  14. hill
    8,183
    China is so awash in coal pollution, converting its energy to hydrogen (lossy or not) serves other purposes ;
    On China's Electricity Grid, East Needs West—for Coal - Businessweek
    Burning coal further away from the congested cities (either for use as hydrogen or electricity) does a sort-of NIMBY ... damaging the health of the less populated western region, making filthy air less burdensome for the east - which is much more densely populated.
  15. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    And I'm convinced it's a waste of time and money. Suggesting electricity and batteries don't exist at a scale to make an impact is ridiculous. Hydrogen is a battery of sorts - an energy storage system rather than a fuel - but it's more expensive and less efficient. Ever since my childhood experiments with a car battery and a bathtub full of water, I've accepted the fact that hydrogen requires more energy input than it yields in output, and I'm not swayed by the seemingly endless hydrogen hype.
  16. Zythryn
    Zythryn Senior Member
    6,258
    4,258
  17. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    How is that different than electricity as an energy carrier?
    Neither is the battery.
    There will be different applications for both but FC has a huge advantage in scaling, battery is linear while FC is logwhich is why I believe it will make the sizable impact.
    Source
  18. hill
    8,183
    And the dishonest fuel cell Lobby funded data website where this was posted? Notice no reference to cost? No reference to the revelation of how cheap GM is getting their traction batteries? No data representing how much pound to kWh's improvement is going on with batteries? How the little chart fails to account for the missing natural gas reformed hydrogen's infrastructure as part of their upward moving graph? Nope - a line on a graph is no substitute for the child's needed brain transplant.
    #18 hill, Nov 17, 2015
  19. Trollbait
    11,560
    Where do PHEVs go on those graphs?
    The gen2 Volt has the same or greater utility as the Mirai, with a ZEV range that will cover most pepople's commutes, while being lighter.
  20. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    It would follow the same path as BEV but slightly worse (due to gas powertrain weight) and drop off the chart as soon as EV range is over.
