29mpg cross country.
Discussion in 'Gen 2 Prius Fuel Economy' started by egmacrae, Sep 6, 2010.
  1. egmacrae
    egmacrae Junior Member
    vashon wa
    I am driving cross country. Now at 1/2 way point. Got 2005 prius serviced before setting out. I have a Tule bag on top of car. I am getting 29.7mpg. I've done this before averaging around 40mpg. Car seems to be running well other then mileage. Any thoughts??
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Did the dealer check and clean MAS, air horn, oil level ( correct level ) Now analyze what has NOT been done for awhile. I see this is your first post, Ever change the 12V battery? Next assignment: Read all post on PC concerning mpg. Next: Read all post on regular maintenace, this should keep you busy til hit the coast.
  3. egmacrae
    vashon wa
    Thanks for your reply.Whatever they do for 70,000 maintenance. Have not had 12v replaced yet. I read that normally the clue for doing this is when you get locked out of trunk. What is MAS can I do myself??
  4. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Tule bag plus headwind plus speeding could cause dramatic loss in mpg.
  5. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    When you did this trip before and got 40 mpg, was that with the Tule (Thule?) bag on the car?
  6. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    we did a trip from nyc to family in indiana with a roofbag. our mpg was low 30s due to wind. once bag cam off car back to to 45-50. the bags seriously effect mileage but we only use them once in a while so i wouldn't be overly concerned.
  7. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    +1, esp on checking/replacing if indicated 12V battery. (~$200 at dealer.)
    Heavens to Murgatroyd!
    This situation is similar to heading for the North Pole and not thinking
    you will need a sleeping bag until you get to Fairbanks. :rolleyes:
    I presume you aren't of a mind to stop for any length of time on the
    road, so here are some "on the fly" items that might help hold/increase
    your FE/MPGs:
    * Pump the tires up to 42F/40R (Check the spare. IIRC, 60psi.)
    * Check oil level -- just below the 'Full" bump is best
    * Keep windows closed
    * Check intake air filter -- if dirty, maybe a service area mechanic will
    blow it out for free (Remove filter from intake air box for this. Ensure
    it is re-installed right-side up and snug.)
    * Drive as slow as your family will permit. The Gen II sees a serious FE
    decrease above 65 MPH.
    * Use Cruise Control except on steeply hilly/mountainous sections --
    except for the very best high-speed hypermilers, CC does a great job
    on FE/MPGs.
    * DO NOT allow the HV battery air inlet vent on the passengers side
    of the rear seat to get blocked.
    Remember P^6...
    Prior Planning Prevents Piss-Poor Performance :D
    Good luck, and drive safely. :rockon:
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    That's not very specific. There's a reason why I put up http://priuschat.com/forums/gen-ii-...-answer-these-questions-esp-if-youre-new.html.
    Unfortunately, your load on top is adding significant drag. It's be interesting to know your mileage (and info about your trips, tires, oil etc.) once your load on top and any roof rack is removed.
    There are a bunch of things you can check and reply back on in the meantime such as 12 V battery level, make, model and size of tires, oil level and viscosity last used.
  9. andyprius
    2,212
    188
    Post 8 covered everything well, search MAS (Mass air sensor). 12 V battery. All covered previously in quantity on Prius Chat.
  10. bisco
    51,140
    are you going north or south?
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    or east or west?!
    Elevation changes + wind + drag + speed = poor prius fuel economy
    Poor prius fool economy >> average fuel economy in any other vehicle
    Our normally average 24-28mpg RX350 gets 17mpg to 18mpg driving cross country with no bag on the roof.
