2g Serpentine Belt Replacement - Replace Pulley also?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bfeinzimer, Apr 14, 2016.
  1. bfeinzimer
    bfeinzimer Junior Member
    Hey all-
    My friend (who is an ASE cert mechanic at a german repair shop) advised replacing the pulley along with the serpentine belt. I can't seem to find anyone else who has replaced the belt via here or YouTube mentioning the pulley, should it also be replaced?
    I do figure replacing the belt is a good time to replace the thermostat since it's in that area also-thoughts?
    TY!
  2. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    When the belt is off you can listen what sound tensioner pulley bearing makes and decide if it needs replacing. If belt wasn’t tightened too much it shouldn’t need replacing. Belt should be pretty lose compared to other cars so it’s commonly over tightened.
    Replacing the thermostat requires draining, filling, and bleeding the cooling system which isn’t easy so if thermostat is working wait at least to the time when coolant is replaced.
    #2 valde3, Apr 14, 2016
  3. bfeinzimer
    Thanks much!
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    The pulley like most belt pulleys has a bearing in it. Its sealed so not serviceable. You don't list the miles on your car but if its making noise its a good idea to replace it. Mine at 90K miles was fine. I took it out and cleaned it then re-used it.
    If the mechanic insists on replacing it buy the oem online yourself. I would not use one from an auto parts store. Same for the belt.
    I would not dig into the cooling system. Its very hard to bleed air out of a Prius ICE coolant loop because of the coolant heat storage tank.
    Not really necessary either as this engine is very easy on coolant. Easiest way is to just dump the radiator only and fill it back up. No air ingress and its about half the system. Do it again in a month. Btw, remove the plastic engine cover over the rad and fill it up and monitor it using the rad cap not the plastic overflow.
    Now, what really needs to be changed is the Inverter coolant. The Inverter is very hard on that coolant. Very easy to bleed that coolant.
  5. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    FWIW, I replaced my tensioner pulley when I did my water pump. You are already there and it is a couple of extra fasteners. My time in this situation is more valuable than having to return at some unknown time in the future to replaces itso I just replaced it while I was there.
    As mentioned above the thermostat replacement is a little more involved and not necessary nor in the same service area when replacing the water pump.
  6. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    I had the pump replaced, too.
  7. Patrick Wong
    18,200
    6,493
    It is a good practice to replace the pulley when the serpentine belt and engine coolant pump is replaced, assuming that your cost of labor is relatively high. I did that.
    Replacing the engine thermostat is an activity which is unrelated to the pulley and serpentine belt, so you are not going to save any labor effort if you combine those tasks. However if your car has logged 150K miles or more, that would be a reasonable thing to do.
    I posted on how to do all of that work here: How to replace engine coolant pump and thermostat | PriusChat
