2gen Red Triangle + Orange Exclamation +VSC + Engine Light
Discussion in 'Gen 2 Prius Main Forum' started by Todd Gack, Jul 15, 2021.
  1. Todd Gack
    Todd Gack New Member
    Hawaii
    Four Touring
    Yesterday I felt a sudden "catching" in my rear brakes like ABS engaged. Then bam my dashboard lit up with the Red Triangle + Orange Exclamation +VSC + Engine Light. I was able to limp along and park it. Car has 150,000 and have owned it 5 years with no problems ever. BTW, had an oil change 5 days ago and rotated tires at Goodyear. They said my brakes are at 3ml. Has anyone else had a similar situation?
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Welcome to PriusChat!!
    Happen to have any OBD2 codes (DTCs) that you can share with us?
  3. Todd Gack
    Hawaii
    Four Touring
    Unfortunately no. I've got an appt with a mechanic on Monday. But wanted to educate myself first on what could be going on and what it will take to fix it.
  4. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    This link might help : Toyota Dashboard Lights & Symbols Guide
    Grab a free basic OBD2 scan at a local auto parts chain, be sure to try each location (even within the same chain) as they may offer a different scanner, and one may be more hybrid compatible than another. Please post the results in this thread for additional guidance.
    If you don't have a set of manuals that you can reference, here is a link : Toyota Warranty & Toyota Manuals | Toyota Owners
    FYI : your posts are being moderated until you've posted five times.
    Todd Gack likes this.
  5. sugar land dave
    137
    houston
    Check the 12 volt battery. Weak battery can cause strange symptoms.
  6. Todd Gack
    Hawaii
    Four Touring
    Appreciate that. Had a new 12v installed in February. Ill have them check it
  7. karen vancampenhout
    karen vancampenhout New Member
    yep what was it?
  8. bisco
    49,500
    maybe a bad inverter pump or tranny
