2nd Dead 12v battery- time for lithium upgrade?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by randy8876, Mar 28, 2023.
  1. randy8876
    randy8876 Junior Member
    44
    17
    seattle, wa
    2015 Prius c
    A few weeks back I drained my 12v battery due to the dome light on too long and since then it hasn't been the same. If the car sits 3 days, the battery will be too drained to start the car.
    This is my 2nd battery to die.
    I feel like the pint sized battery is simply more prone to failure, especially since I've never experienced this in any other car. I have some aftermarket stereo equipment, so that likely cycles the battery a bit extra. I've started searching for a more powerful alternative.
    First off, has anyone tried alternative larger batteries? Like Optima? Or lithium?
    In particular this one has caught my eye.
    https://dakotalithium.com/product/dakota-lithium-12v-60ah-dual-purpose-car-starter-deep-cycle-lifepo4-battery-1000cca/
    It's 60 amp hours and can support high current draw. While expensive, it has an 11 year warranty, so it should be the last battery I buy.
    This battery measures 9.5”(L)x 6.9”(W)x 7.44”(H) vs. 7.62" x 6.81" x 8.75" so it will just barely fit.
    I've emailed the manufacturer asking for their input regarding compatibility.
    Does anyone know of any issues using these in a Prius C?
  2. rjdriver
    rjdriver Active Member
    409
    170
    Rhode Island
    If you've had 2 batteries die I suspect that when your car is off, something is drawing more current than it should. Are you sure that stereo equipment was wired correctly? Does it use a separate amp? Or do you have any other aftermarket items installed that could be the culprit? I would find a mechanic that knows how to do a parasitic load test.
    Montgomery and Mendel Leisk like this.
  3. Mendel Leisk
    41,897
    ^Id second that. Try recharging too, with appropriate amperage (see owners manual) smart charger. You can do this without disconnecting battery (contrary to owners manual).
    regarding height diff, the Toyota hold-down bracket is absurdly intolerant of even a mm height difference.
  4. Leadfoot J. McCoalroller
    8,144
    7,645
    Pennsylvania
    2018 Prius c
    I replaced the dome and trunk lights with LEDs. Another driver in the family is famous for leaving a door slightly ajar for a few days. With the low draw of LED illumination, we no longer have problems.
  5. Shahzad Nayyar
    Shahzad Nayyar Junior Member
    94
    25
    Pakistan
    There is a parasitic drain in your car. You need to locate that first
  6. bisco
    52,386
    leaving the dome lite on will kill a prius battery. sometimes they can be revived, sometimes they can't be.
    led's are a good idea, and larger lithium probably is too, with aftermarket equipment.
