2nd Gen Fuel Gauge Inaccurate, Shows Full Then Drops Quickly
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mercat68, Dec 11, 2021.
  1. mercat68
    mercat68 Active Member
    300
    215
    Mount Airy, MD
    Hoping to get a little direction on my 2007. For the past year or so, the fuel gauge has gotten wonky. It correctly shows full after a fill-up but then drops more quickly than actual fuel usage (flashing the low fuel warning when there's still about half the available range left). Any suggestions on diagnosing and/or fixing? Likely an electronic vs. mechanical (tank float) issue? Thanks.
  2. Another
    Another Senior Member
    1,802
    510
    Naples, Florida
  3. mercat68
    300
    215
    Mount Airy, MD
    Thank you! Daughter's home with the car tomorrow, so will give it a try and report back.
  4. Pdaddy
    Pdaddy Member
    153
    49
  5. mercat68
    300
    215
    Mount Airy, MD
    I was wondering the same thing...
  6. dolj
    dolj Senior Member
    7,505
    3,772
    Wellington, New Zealand
    There is no prerequisite for what level the fuel is in the tank. The procedure sets the zero (or centered) value of the inclination meter, so it makes sense that the fuel level is not a consideration.
    Centered Value Setting of the Inclination Sensor.
    Perform the procedures to correct the inclination of the meter and inclination sensors when installing / removing / replacing the meter or after replacing the inclination sensors or main base.
    The setting prerequisites are:
    1. Connect the connector and install the meter securely in the position shown in the illustration so that it is inclined at a 20 degree angle to the vehicle's vertical line A.
    3. Park the vehicle on a level surface.
    Pdaddy likes this.
  7. mercat68
    300
    215
    Mount Airy, MD
    Great, thank you.
  8. AquaJan
    AquaJan Junior Member
    47
    17
    US
    I know it's been a while but my 2008 is having the same problem with the fuel gauge. Did the inclination reset procedure fix yours? Thx!
  9. mr_guy_mann
    mr_guy_mann Senior Member
    3,250
    1,358
    NJ-USA
    Most likely cause is that you have a worn spot on the fuel level sensor inside the tank. I have had to replace 3 or 4 fuel tanks on customers' Gen2 for this problem.
    You can confirm the fault by waiting until the gauge just reads empty (flashing pip). Then remove the rear seat base and fuel connection access plate. Use a digital multimeter to measure fuel sender resistance per the factory service manual.
    The sender has a resistance range 4 ohms (at full) to 110 ohms (at empty). Usually it will go way above that when it's bad - anywhere fromm 200 ohms to several mega-ohms (open circuit).
    If this is what's happening, then the only repair is to replace the sealed fuel tank assembly.
  10. mr_guy_mann
    3,250
    1,358
    NJ-USA
  11. AquaJan
    47
    17
    US
    Thank you for the response. You're probably right, the reset procedure didn't fix it but I can't see spending $1300 on a new gas tank so I'll just fill up every 350 miles or so.
  12. Rocinante
    Rocinante Junior Member
    45
    Not a permanent fix, but I've noticed on mine that if I run the tank pretty low (315-345 miles), then fill it all the way (after pump stops, slowly add another 1/2 gallon), the gauge works much better for me over time.
    It used to read empty at about 50 miles, now it gets up to 280 miles. Sometimes it will still act weird.
    Peter Larsen, AquaJan and mercat68 like this.
  13. mercat68
    300
    215
    Mount Airy, MD
    It did not. Haven't had a chance to take it to a mechanic. I'll follow up here if I do and have a diagnosis.
    AquaJan likes this.
  14. mercat68
    300
    215
    Mount Airy, MD
    Thanks!
    AquaJan likes this.
