2nd Gen Prius OBD2 Port Not Communicating
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Retsukowind, May 30, 2022.
  1. Retsukowind
    Retsukowind Junior Member
    United States
    my OBD2 port on my 2006 Toyota Prius works partially but when I connect my elm327 obd2 device, it doesn't connect to the Bluetooth elm reader that connects the reader to my phone. I used to be able to read my Prius with any code scanner and look at the high voltage batteries. Now I can't access anything to the check engine light or batteries. How hard would this be to fix or try correcting?
  2. PriusCamper
    PriusCamper Senior Member
    13,200
    5,346
    Pacific Northwest, USA
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,101
    2,003
    NJ-USA
    Could be a problem with your adapter, could be a problem with the female terminals in the OBD connector (you would need a single male terminal of the correct size to check fit when pushed in- there should be slight but noticeable drag when pulling).
    Does that OBD adapter work on another car?
  4. Tombukt2
    Tombukt2 Senior Member
    13,590
    2,454
    Durham NC
    I've noticed similar problems in my gen too and those code readers I tend not to use sometimes if I unplug them and reinsert them they seem like they work but I don't know how deep they go I have text stream on a cf-19 with a dongle that seems to work it's red and it lights up green and red is data moves I don't know how to buy another one to get an extra as the j standard for these things seems to be all over the place the replacement or the piece that I got with the Toyota tech stream computer I bought from the dealer I believe this is a replacement cable but it works
  5. Retsukowind
    United States
    The same code reader used to read my codes on my car for the last two years, now all of a sudden even AutoZone and oreillys AND Toyota's code readers do not read the car even though the ECU logs codes in, and I cannot ream them now.
  6. dolj
    dolj Senior Member
    8,604
    4,366
    Wellington, New Zealand
    The wiring diagram shows a 7.5A OBD fuse (in the driver's side interior fuse block?) specifically for the OBD2 connector. Have you checked that fuse with an ohmmeter?
    #6 dolj, Jun 2, 2022
  7. Retsukowind
    United States
    I did check all of the fuses and none of them are blown. Still puzzled
  8. LDT08
    LDT08 Junior Member
    16
    Did you figure this out?
  9. Dusttttt
    Dusttttt Junior Member
    16
    california
    Did anyone figure this out? I'm having the same problem. I need to get my car smogged, I went to two different places and neither one could "communicate" with the odb2. My cheap personal scanner worked perfectly and i scanned the car and no codes, but the tech told me there's no power on port 16 in ODB2 plug. i put my electrical reader in there and it said 11.4 volts. Does anyone have any idea what else this could be. I checked all the ECU fuses and the ODB fuse and no problem there. the cigarette lighter still works so I don't know what to do
  10. Tombukt2
    13,590
    2,454
    Durham NC
    That 11.4 volts is very problematic that needs to be 12.3 to 12.7 to keep up the electrical system in the car and all the computers communicating so you're 12 V is questionable at best
    ccna101 likes this.
  11. dolj
    dolj Senior Member
    8,604
    4,366
    This is almost urban legend status. I haven't found it to be so. At this level, it is certainly necessary to charge it up before doing further diagnostics. The computers will not complain until the voltage is much lower or you get frequent voltage drops into the less than 10.5 – 8.5 volt territory because the battery has lost all capacity.
    ccna101 likes this.
  12. ChapmanF
    18,716
    The Toyota repair manuals are full of troubleshooting procedures with an early step like this:
    ... which is different, of course, from saying that anything < 11 V means stuff will go wrong. It means that below 11 V you might want to charge or replace it before proceeding to other troubleshooting steps so you don't have to wonder about it, whereas between 11 and 14 V you can just go ahead with the other steps.
    I've never seen a Prius start misbehaving until substantially below 11 V. There are some ECUs in the car that will start logging "hey, did you notice the voltage is low?" codes around 9.5 V. (Those ECUs, of course, are at that point still working fine, and executing their programming to tell you about the voltage reading they noticed.)
    ccna101 likes this.
  13. Tombukt2
    13,590
    2,454
    Durham NC
    Do if 11.5 just sitting what happens under load . That's parking lot test at Menards.
    ccna101 likes this.
  14. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    I think most of you spot on: for all DIY (like me) who only touch TS and OBD2 stuff only once in a blue moon.. check your supplied power for OBD: for my 2007 it is fuse # 8 under your fuse box ... 7.5A and that fix my ABS and TPMS sensor.
    Do not go down a rabbit hole of shotgun troubleshooting ... ask me how I know.:D
