2nd gen prius, will using premium fuel affect my mpg and in what way?
Discussion in 'Gen 2 Prius Fuel Economy' started by Gaby03, Mar 20, 2022.
  1. Gaby03
    Gaby03 Junior Member
    30
    Puerto rico
    Im currently running 93 octane at times 91 depending the station. Im not sure if there is a diference in mpg since my prius mfd does not display properly.
    51,986
    no, it will only affect your wallet
    just use what is recommended in your owners manual
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    The octane number is the fuels resistance to detonation.
    Higher octane fuel burns more slowly to have higher resistance to detonation.
    Burning more slowly can actually cause a reduction in MPG in engines that are not designed to use higher octane fuels.
    The Gen 2 recommended fuel is 87 octane. I would stick with it.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Carbon buildup can cause pinging and detonation. If you are hearing that, then higher octane fuel can help. Otherwise 87 octane, from the most popular station near you is best.
  5. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Gasoline quality, not octane, is what counts. Even many cars like Lexus that say they require premium will run fine on lesser octane with undetectable performance decline, so long as you are consistent in buying same octane else the computer chases its tail trying to optimize.
    Some discount brands sell so-called startup gasoline they get cheap from distributors or blends that don’t have proper additive blends. At current ridiculous prices, the spread between craps gas and top tier is minimal.
    See some layman’s info here.
    https://www.popsci.com/sponsored-post/top-tier-gasoline-detergents
    douglasjre likes this.
  6. Isaac Zachary
    Isaac Zachary Senior Member
    2,550
    1,298
    Oil consumption can also cause pinging.
    If the engine pings with regular fuel 87 R+M/2 (91 RON) then using premium instead will "bandaid" the problem and get you better fuel mileage. An engine in good condition will not benefit from more octane than the recommended octane.
    My suggestion is to see if you do get the same fuel mileage with regular as with premium. If you notice you get better fuel mileage with premium then try to determine what's wrong with your engine and see if you can fix it as the problem will probably only get worse. Next thing you know you have to use racing or aviation fuel to get good fuel mileage if you don't fix it now. So is it burning oil? Or is it coked up with carbon? Is it running lean? Or is your engine fine and gets its best fuel mileage with 87 R+M/2 octane?
  7. Another
    1,819
    517
    Naples, Florida
    Coils or plugs?
  8. Gaby03
    30
    Puerto rico
    ill have to compare numbers after refil and see how much a regular tank will get me. i belive its not burning oil so far. im unsure of the running lean, got no knoledge on testing that.
  9. Isaac Zachary
    2,550
    1,298
    A lean condition would cause the Check Engine Light to turn on. So does constant pinging caused from any reason. Very bad pinging will cause the CEL to flash meaning "Get off the road and turn off the engine before you blow a piston!"
    A hot running engine (stuck thermostat for an example) can also cause more pinging leading to high octane bandaiding the problem. Carbon build up might also cause more pinging too.
    An engine that was previously machined and thus has a higher compression ratio (for an example, a milled head or milled block or both) can also cause more pinging.
  10. douglasjre
    douglasjre Senior Member
    2,181
    720
    Null, NL
    What's the best gas
  11. Another
    1,819
    517
    Naples, Florida
    Most large brands, Shell, Mobil, BP are good quality with plenty of additives. Additives cost money to blend in. Discount brands can be ok, but hit or miss depending on who their wholesaler is. At current prices, stick to quality brands for the few pennies more they may cost.
    When we had refinery upsets years ago during startups, the refinery would offload the off spec ‘startup gasoline’ to wholesalers to sell. I’m sure that has not changed.
    Isaac Zachary likes this.
  12. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Best at what?
    In my opinion, the most frugal gas purchase is the most popular regular unleaded has 87 AKI octane near your home, Gas 'settles' if not used, so old gas tends to be bad gas. You want gas which has not had time to settle.
    If you must buy by buzzwords, ' top tier gas' is a good buzzword at a popular station.
  13. Isaac Zachary
    2,550
    1,298
    My Toyota owner's manual specifically recomends Top Tier gasoline.
