2nd Key Fob dead. Where's the battery??
Discussion in 'Gen 2 Prius Main Forum' started by ewxlt66, Nov 21, 2012.
  1. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    I'm a tech newb. Would love some input on getting 2nd fob to work again.
    Or point out a thread where this has been answered.
    Thank you!
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
  3. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Any drugstore will sell these batteries, CR2032. You will need one for each fob.
    I suggest that you do a search to find out how to replace the fob battery if you can't find that in your owner's manual. This task may not be that easy to do and depends upon exerting some force with your fingers.
    Here is my short description:
    1. remove manual key - hold key fob with with buttons toward you (key ring to top) - push latch to the left - pull key up and away from you with right hand - remove key
    2. turn key fob over (buttons away from you latch on the top) - push latch to the right with left thumb and push whole back cover up with the right thumb -
    3. You will need a very small Phillips jewelers screwdriver to remove the four screws that cover the battery once you have removed a trim cover on the fob.
    4. remove and replace the battery and screws
    ewxlt66 likes this.
  4. ewxlt66
    535
    186
    Dana Point, CA
    Thanks gentlemen!
