$3,000 Head gasket repair? 2013 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jennifer150, Aug 15, 2020.
  1. Jennifer150
    Jennifer150 New Member
    Arizona
    My local mechanic quoted me $3,000 for the head gasket repair on my 2013 Prius. So at first he wouldn't give me a number to fix it. I was going to do it myself with a lot of help from my dad(we've done a cavalier and a subaru prior to this together) but also going through a divorce and my husband is getting this car. My dad changed his mind and I don't have the confidence in my own abilities to fix it myself. (I am dead set on getting this car fixed because I need to know my kids have safe transportation with him. It just feels right to me and its what I'm going to do. I don't want to buy another car because that's how I ended up with two used cars with bad head gaskets, the above mentioned subaru and cavalier.)
    So I started bothering my mechanic again and he threw out a number after a while of research and said $3,000 with 18 hrs of labor being a expensive part, the milling of the head and a valve job as well.
    So My question is, is $3,000 to much? I have only used this mechanic since for as long as I have been driving so I don't really trust any others. But, should I shop around at that high of a price? I saw another thread saying a dealer is charging for a head gasket at 3,300?
    Thank you in advance!
  2. JC91006
    16,049
    8,191
    For $3000, I would shop for a newer engine. No need to fix something for $3000 when you can put in a lower mileage engine for the same price
    Jennifer150 and Raytheeagle like this.
    46,684
    definitely shop around. how many miles on her?
    you would also need to clean the egr circuit, another grand unless you diy
    Jennifer150 likes this.
  4. Jennifer150
    Arizona
    It’s got over 210k miles on it. I could clean the egr myself. It’s just never had a code or anything and I didn’t know that was normal maintenance that needed done
  5. bisco
    46,684
    if you can do it, do it, before the head gasket blows. see @NutzAboutBolts youtube channel
    NutzAboutBolts likes this.
  6. Montgomery
    Montgomery Senior Member
    2,152
    2,154
    Orange County, CA
    I can understand your situation. The above suggestions seems relevant and good for you. I'm kind of concerned about the mechanic you had to push for an estimate. Just leaves room to wonder what kind of job he would do.
  7. ttou68
    ttou68 Active Member
    307
    191
    I would suggest to consider replacing engine water pump with head gasket replacement, since your Prius has 210K on the clock to prevent another head gasket failure in the future...
    mjoo likes this.
  8. fuzzy1
    9,600
    Neither did anyone else, until long after we bought these cars.
    Mendel Leisk and scona like this.
  9. orenji
    orenji Senior Member
    5,881
    3,482
    Swapping in a Gen4 motor is the best option.
  10. mjoo
    mjoo Senior Member
    1,089
    1,301
    Michigan
    Agreed. You could get a low mileage gen4 engine with an almost new water pump and head gasket installed for that price. They also have improvements to the engine block and piston rings.
    But I would still clean the EGR system. Either clean and install the EGR system yourself or spend another grand on new parts and installation.
  11. Gliderguy
    Gliderguy Junior Member
    47
    Prescott Valley, AZ
    All the above is good advice, 18 hours of labor is not out of line for what it might really take. If you do take it on yourself, the Nutzaboutbolts youtube videos are a good place to start. The video I used was about 30 minutes long, but it was like "remove this, this and this" then it would cut to that work being done, and continue like that. I have looked for but cannot find that same video. If you DIY it would be a long weekend, or more likely, a full day, then some time to get the head milled and the valves checked, and then a long day putting it all back together.
  12. Grit
    Grit Senior Member
    5,896
    3,960
    Wilkes Land
    Since you already traded the husband in, let the blown gasket car be a bonus trade in value.
    #12 Grit, Nov 11, 2020
  13. ETC(SS)
    6,250
    They have kiddos....so keeping the G3 on the road might not be optional...and besides, the OP seems to be.....shall we say....."unlucky" in picking out used cars.
    SO....
    We have a 2013 G3-two, in Aridzona (non-CARB state) marginally maintained, and with.....probably 150,000 miles on the clock more or less.
    Aridzona is a good climate to own a car in, but the heat can be kinda tough on the traction battery - so beware of this and start planning on learning how to swap this piece out.
    Me?
    There's no way in heck I would repair this motor.
    Go with the heart transplant.
    I'd source a new motor AND a new mechanic, since whoever your present wrench is should have pointed this out as a less expensive alternative, and probably should have ALSO pointed out that NORMALLY head gaskets do not fail in Priuses for the same reason that.....say....timing chain cover gaskets do. :eek:
    Head gasket failures in Priuses are kinda like political division in America.
    It's mostly not THE problem...it's mostly a SYMPTOM of the problem.
    So...if you decide to rehabilitate this car instead of dumping it (I'll leave the obvious marital tie-in mostly un referred to ;) ) then there's a couple of ADVANTAGES to not living in a 'worker's paradise.'
    Example:
    You get to decide whether or not you want to use an OIL CATCH CAN on your car.
    Good Luck!
  14. douglasjre
    douglasjre Senior Member
    1,394
    518
    Orlando, FL
    This price is perfect. But replacing an engine is not cheaper. just the same I would replace the engine because you probably have some oil consumption. I've replaced the head gasket only to have it blow again 10,000 mi later period beware of cheap head gaskets. I got another Prius here with a blunt head gasket. This car is getting a replacement motor. This is a $4,000 job with a 2015 motor 40,000 mi on the one coming
  15. rjparker
    rjparker Tu Humilde Sirviente
    6,149
    3,524
    Texas Hill Country
    210,000 on the 2013 engine and a bad head gasket. It is not that uncommon especially between 2010 and 2014.
    I do think you could get it done for less, there is a company in California that does them for $1500-2000 depending on the head condition. Finding that price might depend on your actual location in Arizona since the number of Prii probably has more to do with it then anything. Your mechanic may not have a lot of Prius experience and is covering himself. Or he may be concerned about comebacks, which do happen on these engines.
    My almost daily advice for head gaskets on high mile gen3s is to get a lower mile gen3 engine and have it rebuilt. No more oil use, no leaking timing chain gaskets, clogged egrs, etc. Some have had that done recently for $3k-$4k.
    Honestly, I don't think you should be paying to fix your soon to be ex's car. Let him do it.
  16. Mendel Leisk
    Mendel Leisk Patron saint of newly poured sidewalks
    36,369
    @NutzAboutBolts videos are linked here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    Merkey and NutzAboutBolts like this.
  17. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,478
    1,548
    Bay Area
    here's a video for you.
    they had a second video of the same head gasket removal but they since removed it from their youtube account. Not sure why... but I got the video saved.
  18. Mendel Leisk
    36,369
    Puzzled me too, and I also saved both their earlier videos. Guess who else's videos I've saved, lol.
    Frustrating: if you share it's a copyright infringement I think.
    NutzAboutBolts and Merkey like this.
  19. NutzAboutBolts
    1,478
    1,548
    Bay Area
    lol, so if my YT page gets taken down, I'll come looking for you so I can reupload all my videos ;) :ROFLMAO::ROFLMAO:
  20. tony_2018
    tony_2018 Member
    202
    59
    Engine swap. More peace of mind.
    douglasjre likes this.
Loading...
