3 out of 4 doors won't lock/unlock
Discussion in 'Gen 3 Prius Technical Discussion' started by suirPPrius123, Sep 23, 2021.
  1. suirPPrius123
    suirPPrius123 Junior Member
    22
    Usa
    All my doors (except rear driver side door) won't lock/unlock with the key fob AND won't lock/unlock by pressing the luck/unlock button on the driver's door.
    The rear driver door works as designed! What a strange problem.
    When I press lock/unlock, I hear a clicking sound under the steering wheel, but 3 out of 4 doors don't respond.
    What could this be?
  2. Grit
    Grit Senior Member
    6,563
    4,222
    Wilkes Land
    Check yer 12v battery health.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,800
    2017 Prius c
    GASP. What a novel suggestion. :)
    If that is OK, then it's likely that you have 3 door lock solenoids that have failed.
    VERY common failure. I think they are usually called "actuators".
    Alas, if Toyota fixes it, the cost is outrageously high.
  4. suirPPrius123
    22
    Usa
    Seems like it's the motor on the actuator that goes bad. This guy just cleaned the brush contacts and it fixed it.
    . That may be a cheaper solution. Each actuator is around $50 third party.
  5. bisco
    51,498
    did they all start at once, or one at a time?
  6. amarino
    amarino Active Member
    136
    102
    99
    Had similar happen to me first the drivers side then like a year later the passengers side. I think they were like $300+ each for the whole assembly that the dealer replaces, but luckily was still under warranty for both.
  7. sam spade 2
    7,035
    2,800
    2017 Prius c
    PLUS another $300 or so in labor.....for a total of about $600 each.....IIRC.
    I had a similar situation but my second one was out of warranty so I traded it in. :)
