  1. Brian Adcock
    Brian Adcock Junior Member
    NC
    Good evening
    I replaced my inverter pump today.
    Should I replace the 3 way valve proactively as well?
    What do you all think?
    The inverter pump was very straight forward and the hose clamps were brilliant!
    Thanks for your insights....
    Brian in central NC
  2. Tombukt2
    Tombukt2 Senior Member
    9,249
    1,620
    Durham NC
    I'm up here in Efland I would just wait until it fails You can do anything you want proactively maybe it's been replaced already by the last owner who knows they generally tend to go to about 200-250,000 or it's already been placed possibly by mistake before because well whenever happened the coolant control valve generally won't create a whole lot of hullabaloo when it starts to go bad you'll notice some weird things happening in relation to how things are happening but that's about it slow down and get where you're going and change it when you get a minute by the time it cools off you'll be able to drive again for quite a bit until anything really goes on but generally there's no reason to proactively do that.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,248
    5,947
    Columbia, SC
    The only time I preemptively replace the coolant control valve and the ICWP is if I'm doing a brake actuator job.
