30 Minute Sparkplug Change :)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 05PreeUs, Oct 30, 2016.
  1. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    With each consecutive maintenance procedure, I become ever more impressed with the engineering on these cars.
    I have changed THOUSANDS of sparkplugs on hundreds of engines, but given the apparently difficulty of this on a Gen 2 Prius, they were shockingly easy to change. Despite the records indicating plug change about 80k ago, our car developed a VERY intermittent misfire with flashing CEL (engine shaped light). Research led to the likely cause of misfire induced by sparkplug(s). I hold shops in dim light and expected to find el-cheapo Cu plugs that were wrong for this vehicle, but I was proven wrong; the correct NGKs were used.
    In any event, there was moisture in two of the four plug wells and rust in #1, easily explaining our symptoms. Given there was no DTC logged, I checked FIRST, I am confident that the defect was caught in the very beginning stages.
  2. JC91006
    16,832
    8,603
    Gen2 services are fairly simple to do. This is probably the best and easiest diy vehicle out there
    Aaron Vitolins and bisco like this.
  3. 05PreeUs
    1,097
    565
    MSP
    DIY is as easy on a Subaru as ANY vehicle I have ever seen, but the logical lay-out and engineering of the Toyota is hard to beat!
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I DIY oil changes on all my vehicles over the years and our Outback is, by far, the easiest and most thought out of all of them: ride height is high enough to not need ramps or jack stands to get underneath and the oil filter mounted up top, up front, and upside down so it drains back into the engine. (y)
  5. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    My '98 Outback with the 2.5L is a very hard spark plug change. Yep, the Prius is a snap for many routine tasks. Flushing brake fluid and changing engine coolant are among the exceptions, though with the MiniVCI they're not so bad.
  6. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Hopefully you applied some caulk or a new rubberized weatherstriping (Shop M-D Building Products 0.75-in x 10-ft Black Sponge Rubber Window Weatherstrip at Lowes.com) to replace the factory seal in the middle of the cowl.
    Post 1 has images of the original seal; Hood cowl engine compartment water seal questions | PriusChat Yours are probably well worn or gone.
    This center cowl seal is a common problem on Gen2s.
  7. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    Probably should've changed the PCV too while all that stuff was off.
