300K Miles, One Prius/One Owner
Discussion in 'Gen 2 Prius Main Forum' started by CBarr31, Aug 17, 2012.
  1. CBarr31
    CBarr31 Active Member
    436
    225
    Charlotte, NC
    Ema rolled 300,000 a couple of weeks ago. She is currently at 302,636 and counting. The delay in posting is because I wanted to add all the 300K service costs into my lifetime upgrades and maintenance cost before posting.
    Lifetime MPG = 46.97 (As of 1/1/12 from 591 fills since purchase, sorry haven't updated this yet this year. Really only doing it once a year now.)
    - Purchased on March 28, 2006
    Lifetime Upgrades and Maintenance = $12,523 (Yes this is high but includes everything.)
    I am only going to update this thread with upgrades and maintence from 200K on. If you want to see everything that was done before 200K and my write up for getting there it is at:
    200K Miles, ONE Prius & ONE Owner | PriusChat
    At 205K - Replaced inverter pump, heat storage pump, SLLC, serpentine belt, ATF, plugs and battery with a new yellow top. Plus all the regular throttle body cleanings, EFI and stuff. ($1,200)
    At 208K - I had my first and ONLY part failure, knock on wood, the water pump took a dive and was leaking. Level was low and giving a high temp on my scangauge along with the triangle of death. Yeah Yeah Yeah, big oopppsssyyy on my part. Since I just replaced the other pumps why in the hell didn't I do this one, LOL. ($500)
    At 210K - I purchased a new Nav DVD, Version 10.1 ($220)
    At 253K - I did the ATF again along with other "regular" maintenance. ($154)
    At 255K - Suspension upgrade to Touring Edition components including stabilizer bars, new shocks, struts, etc... Also put 4 new Michelin Harmonies 185/65 R15 on her and completed mount, balance, alignment, etc... More on the Harmonies later. ($2,200)
    At 302K - Oil & Filter change, new PCV, Induction & EFI service, new brake fluid, tire rotation, alignment and had the dealer restore the headlights, new HID's as well. ($850)
    I didn't put all the oil changes and alignments in the list along with any other "routine" maintenance such as wipers, air filters and stuff like that.
    NOTE: She is burning about a quart of oil every 2,000 - 2,500 miles which is actually phenomenal for a car with 300K miles. I did switch to high mileage motor oil this last oil change and plan on putting in a can of restore the next time she needs "topped off". I will certainly report back as to how the high mileage oil and restore works out.
    I am still on the original hybrid battery, knock on wood, and plan on pushing it until the wheels fall off. I have inquired to Re-Involt about the lithium upgrade but have also talked with my local service manager and he thinks they may split the cost of a new battery with me. They kind of want to see how long everything lasts like I do, LOL.
    I plan on replacing ALL the pumps, this time, at about thee 350K mark along with completing all regularly scheduled maintenance. With Ema doing mostly highway driving I think 400K should be achieveable on original components and would really like to make 500K. Problem with that is I really want a new one with adaptive cruise. That would be really useful with all the highway driving I do.
    Favorite Upgrades:
    1. #1 with a bullet - Michelin Harmony 195/60 R15 tires.
    - I didn't realize how much of a difference the larger tires make until I put stock 185/65's back on. It is a HUGE difference and I strongly recommend upgrading to the larger tire. I thought with the suspension upgrade, tower strut brace, BT stiffening plate, etc... that the stock tires would be ok. Wrong, lol.
    2. Tower Strut Brace - The better handling makes a huge difference.
    3. Dynamat Extreme - Sound deadening really helps muffle the road noise and even though Ema doesn't have any real rattles I would like to think the Dynamat would help there as well.
    4. Dice - All the long highway miles and hours makes a Dice mandatory.
    5. Et all - The rest of the upgrades I would do again but big things like the suspension and BT skid plate would only been done because they are needed. Why not upgrade to the Touring suspension if you are replacing the shocks, struts, etc... It makes a difference and really doesn't cost that much more.
    Favorite Standard Features:
    - All of these are still the same as listed in my 200K write-up.
    Least Favorite Features:
    1. Gas Tank Bladder - This has been discussed at length all over this site, lol.
    2. 106 Nav Points - Same as in 200K report. I really would like more points to register.
    3. Loss of Braking over bumps, potholes, train tracks, etc... - Again something that has been discussed, debated, analyzed, etc...
    All and all just as in 2010 I can easily say this is the best car I have ever owned and I plan on keeping her as long as I can. Hopefully that will be at least until a 400K write-up can be completed and maybe beyond.
    I hope everyone enjoyed this little write-up and if anyone has any questions just let me know.
    Happy Driving,
    Chris
    08/17/2012
  2. jdenenberg
    jdenenberg EE Professor
    3,941
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    MakesMeLookSmart, my 2004 Prius, is now at 228k miles and has averaged 45.9 Lifetime MPG - not as impressive as Ema.
    Repairs:
    • My HV battery died at 195k miles (replaced with a ReInVolt-$2000)
    • both major coolant pumps replaced at 150k miles
    • My intermediate steering column assembly needed replacing-$1000
    • Struts at 150k - $750
    Maintenance
    • All oil changes at 5k intervals with syn oil - $20 DIY
    • Coolants at 100k, 150k, 200k
    • Plugs and PCV at 100k
    • ATF changed every 60k miles - $100 at Dealer
    • Optima Yellow Top at 200k - $175 DIY
    Surprises
    • Still on the original Brakes!
    Upgrades
    • Tires - Using Nokian WRg2 tires - great traction in all conditions and reasonably quiet.
    • Stereo - Dumped the lousy OE stereo (poor sensitivity, unreliable CD drive) for a Pioneer HD33 - $250
    I expect that my ODO will stop registering miles at 299,999 but that is still more than two years away (more as my driving is slowing down as I get older and hopefully pEEf will still be around to fix it). I have saved about $14,000 in gas costs to date; these are great cars. Thanks for the update on Ema.
    JeffD
    ps: the electric motor/generators are integral to the tranny - not a separate repair item.
    Dino33ca and ewxlt66 like this.
  3. has been
    has been vote for anyone except Trump
    254
    46
    pacific n'west
    Interesting car to own in a town that touts the Nascar Hall Of Fame.
    Great report, thanks, good luck!
  4. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Thanks for your report CBarr31:)
    Hope mine does as well. H
  5. oliverelvert
    oliverelvert New Member
    I own a 2005 prius and suddenly the battery it is not holding charge for very long periods the main engine seems to be working most of the time ,rear fan is on almost all the time. and getting 25 mpg . does anyone know if the hv battery went bad anyone??
  6. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    Do you have any warning lights? Where are you located?
  7. oliverelvert
    yes a red triangle sign, and located in fairfax VA
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    In the future, it'd be better to start your own thread or piggyback onto an existing troubleshooting thread than to add to a thread started by a guy w/300K miles on his Prius.
  9. pappyt
    pappyt Junior Member
    59
    i would not use the restore additive, i did in another car and it made oil consumpiton worse
  10. josh2008
    365
    144
    Princeton, WV
    You have a new PM.
  11. CBarr31
    436
    225
    Charlotte, NC
    Thanks for the recommendation on Restore and sharing your experience. I have a couple of questions. How many miles did you have on the other car when you used Restore? Had this car been running synthetic or standard dino oil its entire life? Did you have noticeable smoke from the exhaust or just internal burning before/after use?
    I have put about 3,000 miles on Ema since the change to Pennzoil High Mileage and she might be doing a little better with the high mileage oil. She seems to be buring a quart every 2,500 - 3,000 miles. Which is either slighlty better or the same because I wasn't really monitoring as close as I should have until just recently.
    As for Restore, I have not put any in the car yet so I might see how a couple of oil changes go with the high mileage oil before adding it. The best I can tell it simply has higher concentrations of the seal conditioners, cylinder wall conditioner and other ingredients that are added to high mileage oil. If that's the case I can't see it making things any worse than running high mileage oil in her for the next 100,000 miles. Restore was recommended by a couple of different people here and since some of them are building cars for Sunday drives with a lot of left turns I think its probably ok. Still like to hear about everyone's experience though.
    Thanks again for responding and as always happy driving!!!!
    Chris
  12. CBarr31
    436
    225
    Charlotte, NC
    Update time on Ema and the results of Restore. I used the restore an oil change or two ago and haven't seen any noticeable improvement in the oil buring rate. Now that I am monitoring it more closely she is burning a quart every 2,000 - 2,500 miles. This is a little lower than my guess a couple of posts ago but that was more of a guess because I hadn't really been watching the oil consumption any and now I am.
    I use the "Engine Oil" setting under Info-Maintenance and set this to 2,000. When it comes on I check the oil, top off and reset it. Do it again the next time it comes on and then when I get the maintenance reqd light on the dash, or there abouts, I take her in for her 5,000 mile oil and filter change and free tire rotation. This system seems to be doing fine and will hopefully get me to 400,000 miles. Ema is currently around 313,000 miles. The next big maintenance issue is I will be replacing all the pumps around 350,000. This hasn't been done since the 200,000 mile mark.
    One thing interesting about the restore is about 10 miles after the oil change when it was added I got an error code, forget which one sorry, for the little mesh filter in the engine housing compartment. I think this is the little mesh filter protecting the cam shaft position sensor or in that area. Code may have been P011? Anyway I had Toyota reset it and it hasn't come back. It probably occurred because all the metal fines and additives in the restore temporarily blinded off the little mesh sensor but after the oil circulated through a few times and was nice and hot the fines/additives went away from the sensor and either to the piston scarring like is supposed to happen or out through the catlytic converter which probably happened, LOL.
    Anyway, that's the update. Basically no real issue with Restore but it hasn't seemed to make the oil consumption any better or worse either way. My take on the product is ... give it a shot if you want to try it or don't if you aren't comfortable with it. I'm not going to condemn it like some or endorse it like others.
    Happy driving,
    Chris
  13. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    thanks for the thread about Ema; i just bought my '04 prius back from my brother (sold it to him 2 1/2 years ago). its got 179k on it and you give me hope that it was a good move. if i can get to 400k (sometime in 2020) i'll be a happy camper. i put 205 tires on it and they grip well. i've also installed a corolla front sway bar and thm rear; it handles almost like a sports car.
  14. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    Thanks for the great write up on your little lady!
  15. joe350gt
    joe350gt It's too windy here...
    40
    38
    Wichita, Ks.
    My '05 has almost 292K right now so I hope to hit the big 3-0-0 next Spring!! What a beast this little silver streak is!! I will post details/pics when the big day arrives....
  16. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Has anyone started a 300k mile club yet?
    Alan...
    Sent with Tapatalk 2
  17. smokiejoe
    smokiejoe Member
    178
    30
    PA
    I thought most Pri odometer stops recording at 299,999. Apparently this is not the case. Can someone clarify. Thanks, SJ
  18. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    If there is one, it has not been made a sticky yet. Maybe this string should be one.
    Ian Wong likes this.
  19. HaroldW
    716
    95
    There is one. Do a search. There is a 200 as well. H:)
  20. longbow
    longbow Recovering SUV Owner
    62
    34
    Bayfield County, Wisconsin
    Looks like you are driving about the same amount annually as I have been. 229,000 on the 2008 since i rolled it off the lot as a brand new car on 2/14/2008......No reason to slow down now!
