30k maintenance
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by yoyoman, Jan 30, 2008.
  1. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    What is the recommended 30k maintenance? I'm living at Cupertino CA area and I bought my prius at New Mexico.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
  4. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Did your car come with an owners manual and maintence guide? If not the only things that need to be done are Engine oil and oil filter, engine air filter, cabin air filter, rotate tires.
    This link's directions are not completely accurate.
    It leaves out Replacement of Cabin Air Filter,
    and makes unnecessary referrence to a manual transmission
    What ever happened to referencing the car's scheduled maintenance guide, that s/b in everyone's glovebox? G
  5. richard schumacher
    7,663
    1,038
    United States
    If you don't have both the owner's manual and the scheduled maintenance guide (they are separate documents) buy them, read them, follow their advice. They will save you a lot of trouble and expense.
  6. yoyoman
    342
    117
    San Jose California
    The reason I'm asking is that recently when I power down my prius, I've been hearing weird noise beside the pump noise. I think the pump actually making a higher pitch that normal just once in a while. What happen if the pump is totally not working in one day?
  7. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Mine gets noisy when the weather turns cool. It has been like that for four winters. The noise goes away during the warmer months of the year.
  8. yoyoman
    342
    117
    San Jose California
    my 3yrs warranty is going to expire on July08. I better send my car for a check up.
  9. dovepistil
    dovepistil Junior Member
    Olympia, WA
    'sounds like bad bearing on the coolant exchange pump, a known Prius weakness. I just had mine replaced under warranty. My dealer did his best to wiggle out of the job. You may have to insist that the thing DOES scream, even if you can't make it play for them. This is not a cheap fix. Do get them to do it while you have time.
