33,000 miles
Discussion in 'Gen 2 Prius Main Forum' started by Sheepdog, May 3, 2010.
  1. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    I now have 33K on Rachel and want to ask:
    Is their anything I should really have done before I hit 35K and lose warranty?
    I lost my job in early april so buying an extended warranty wouldnt be such a good idea really. I'm concerned about keeping the house right now. Two months and the 401K money will be exhausted. But back to the warranty.
    what should I get done or checked? she seems perfect so far. synthetic every 6K and syn filter as well. New tires 1000 miles ago (the originals just started to fall apart) I got Cooper CS4's and they are fine.
    I havent had a 30K checkup yet but am concerned about what it might cost me.
    Your thoughts please?
  2. Patrick Wong
    18,200
    6,479
    Considering your financial situation, I recommend that you limit your Prius maintenance to engine oil, oil filter, and engine air filter changes. Since you are using synthetic oil you should be able to move to at least 7,500 mile change intervals; 10,000 mile intervals would be feasible.
    I'd also recommend that you forget about buying an extended warranty program. I'm sure you can find a better use for $1K.
    Good luck.
  3. sktn77a
    sktn77a Member
    294
    NC
    With oil and filter changes every 5000 miles (cost me $37 at the local Toyota dealer, including tire rotation), your Prius should go to 60,000 with no problem. A couple of additional items at that mileage aren't that much more expensive. No timing belts, etc, and no need for an extended warranty!
