34 mpg
Discussion in 'Gen 2 Prius Fuel Economy' started by Sprockit, Feb 12, 2017.
  1. Sprockit
    Sprockit New Member
    Okc ok
    This is my first prius.
    2008 93kmi
    205/60/16 45 psi
    Please help
  2. srellim234
    srellim234 Senior Member
    1,198
    1,687
    Laughlin, Nevada
    Deleted....Double post. Please see the next post.
    #2 srellim234, Feb 13, 2017
  3. srellim234
    1,198
    1,687
    Laughlin, Nevada
  4. Sprockit
    Sprockit New Member
    Okc ok
    Cool thanks
  5. Sprockit
    Sprockit New Member
    Okc ok
    1 I did not read that thread yet, thank you.
    2. Mpg clatulated by computer, when I did it manually it was so close all the time so I quit with the math.
    3 I am expecting at LEAST 40 mpg this is a prius after all..
    4 air temperature about 60degrees
    5 my trips are short as my primary use for this vehicle is to deliver Pizza, 90% of my driving g is below 60 MPhil
    6 don't remember the last time I spent more than 15min on the hiway.
    7 OKC
    8 mostly flat terrain
    9 not sure of my oil level, I know that they added about 3.6qts
    10 12 volt battery, never checked.
    11 Alignment just done, steering rack just replaced too.
    12 douglas performance, 205,60,16 @45 psi (I wanted a taller tire for more ground clearance as I scrape on driveway aprons all the time.
    13 used to have an 08 yaris manual, before that 94 geo metro Auto, both of those cars got 35mpg delivering pizza with oem tire sizes.
    14, driving style??? I'm 35 so I'm not Racing around like a pissed off teenager and I'm not on a Sunday drive either, I'm trying to get the customer their meal while it's still hott.
    15. I turn it on and go like most people. But sometimes I give it a min.
    16 driving in D mode, every one on YouTube has a different explanation of what B is, so I don't mess with it.
    17 hvac... when in use always in Auto. Never set colder than 72, never set warmer than 76
  6. Sprockit
    Sprockit New Member
    Okc ok
    Any tips, tricks, suggestions for accessories (like a tuner ex. bully dog for a diesel) that wold help mpg without "slowing down" would be greatly appreciated.
    K&n air filter in the near future
    Different type of oil? 0w20?
    Comp thinks I'm getting 34mpg. Anyone know what I'm actually getting with the 205,60,16's instead of the factory 195,55,16
  7. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    I use my AC all summer (17c - 19c never more than blower position 2), but manual settings only - I never switch it to Auto, as that uses more fuel, I believe.
    It seems you do a lot of short journeys. The Prius is most economical when the engine is warmed up and you're doing longer journeys.
    Having said that, swot up on hypermiling techniques and that might help you elevate your MPG.
    Do you actually have LRR tyres fitted? Y'know, Low Rolling Resistance tyres that'll help save fuel?
    For repeated short journeys where the engine never fully warms up you'll end up with less mpg.
    Climate; is that 60f....?
    Could be your tyres.
    iPhone ?
    srellim234 likes this.
  8. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Those tires have about 5% bigger circumference. So that would be the difference between 34 and 36MPG.
    K&N filter won’t really help you. Modifications on Prius don’t really help much with fuel economy.
    When you drive how hard do you brake to stop? Big difference between the Prius and normal car is regenerative braking. If you brake hard Prius uses normal brakes loosing energy.
    When you deliver to customers do you turn the Prius of at their end? Turning the Prius on and off all the time wastes energy.
    Data Daedalus and srellim234 like this.
  9. srellim234
    1,198
    1,687
    Laughlin, Nevada
    Sprockit - All the short trips really hurt the mileage. Our mpg often averages low to mid thirties during the winter when the car is only seeing short jumps of 1-5 miles at a time all week long and that is not even factoring in the colder weather. Early in a tank I often see 29 mpg on the screen.
    With your car being the same year and the a Touring like mine I'm assuming you have the Smart Key. When it's safe to do so try to leave the car turned on when you are delivering those pizzas. With the Smart Key you always have the panic button on you , the key isn't in the car and both Data Daedalus and valde3 are correct. The gas engine automatically starts every time you hit the start button whether the car is warmed up or not. That alone will really kill your gas mileage.
    As long as the car still gets in the 40s on the highway there's probably nothing wrong with the car but I do have one other suggestion if it doesn't. Get the brakes checked to make sure the emergency brake is releasing all the way and check that one of the other brakes isn't "dragging".
    #9 srellim234, Feb 13, 2017
    Data Daedalus likes this.
  10. Sprockit
    Sprockit New Member
    Okc ok
    Yes I did notice that if I leave the car on when delivering my mpg goes up, but I wasn't sure if it just "thinks that" or if it actually did, I try to break slowly, you know taking longer to stop...
    I doubt the tires are LRR.
    Ok I will do a test I'll hit the reset button and leave the car on (most times)most times. when on delivery some places are bad areas and I wouldn't want to leave the car on, To bad I cant leave it on, lock it and walk away.
  11. Sprockit
    Sprockit New Member
    Okc ok
    I just had the caright in the air at the shop. After years of owning a truck the rear wheel free spin check is a regular thing I do.
  12. Sprockit
    Sprockit New Member
    Okc ok
    Given its primary use would I be better off with a tdi? Swift or Toyota echo?
  13. srellim234
    1,198
    1,687
    Laughlin, Nevada
    If you are going to continue to use the car primarily as a pizza delivery vehicle you're going to beat up any vehicle you use. Make sure whatever you drive is a solid performer and dependable.
    As a comparison we bought a 2007 Toyota Yaris in 2015 for my wife to commute to the train station for work. 8 miles each way with low speed limits. A lot of signals and stop signs. She has averaged 32 mpg with that car. We averaged 33 mpg with the 2003 Echo we had before that but the mileage included a little more 65 mph driving on the highway.
    Personally I wouldn't switch unless I could sell the Prius for more than what I could replace it with. To take a loss will never be made up by the few Euros you might save with a few mpg of improvement. Also, I don't think it's worth the risk of buying a different used vehicle and possibly getting someone else's problems in an attempt to save what amounts to only a minute quantity of fuel per month. I would continue to drive the Prius (a nicer car) and set aside a savings account for that inevitable day when a replacement is needed.
  14. valde3
    2,002
    745
    Finland
    You can lock the Prius running. But then you do need the mechanical key to get back in. So this probably isn’t practical.
    TDI is only good for longer highway drives (some would say that it’s not good for those either).
  15. bisco
    49,698
    probably just a civic or something simple like that.
  16. Sprockit
    Sprockit New Member
    Okc ok
    Back to the geo metro... hood for everything! Lol
  17. srellim234
    1,198
    1,687
    Laughlin, Nevada
    Sprockit - To give you some perspective, we just went and filled the car after 177 miles because we're going to be driving a couple of hundred miles tomorrow and I don't want to mess with it then. This 177 miles consisted of no drive longer than 4.8 miles in cool (by southern California standards) temperatures and rain. End result was only 33.58 mpg but I'm not worried. We'll get mid 40s to 50 mpg tomorrow on the freeway as we run to L.A., Orange County and back.
    Allowing the car to warm up and longer trips make a huge difference.
  18. fuzzy1
    10,254
    Short COLD trips hurt MPG. But if you are doing many of these trips back-to-back, with the engine staying relatively warm in between, these short runs shouldn't hurt nearly as much as short commutes with 8+ hours of cooling between trips.
    CHECK THE OIL LEVEL!!! Nevermind MPG, this is for protecting the engine. Neglected oil and undetected low levels have caused way too much unnecessary damage. Some models (e.g. my first Prius, a 2010, and now my 2014 Subaru) are notorious for developing oil consumption problems. Drivers who never check oil themselves end up learning this the hard way, after permanent damage crops up.
    12V batteries on the verge of failure are a common contributor to low MPG, especially in winter, especially in the few months before they give up the ghost. Check it, use the procedure listed in one of the above linked threads. Your Gen2 has a built-in voltmeter accessible from the dash menus. Other generations lack this built-in meter.
    This tall tire hurts displayed MPG in multiple ways, some of it real, some of it just illusory.
    That tire is about 5% taller than OEM, throwing off both the speedometer and odometer. You are going 5% faster than the speedo says, which makes a difference if you are looking at Bob Wilson's MPG-vs-speed chard. This hit is real.
    Your odometer is also under-reading. When it says you have driven 40 miles, you have really gone 42 miles. This hit to MPG is illusory, because it is calculated from a 'fake mileage'. Adjust your displayed (or computed from odometer) MPG numbers up by 5%.
    If the tires are not LRR, you may lose several percent compared to better tires, but this is almost never a reason to discard otherwise good tires, as the saved fuel will not cover the cost of throwing away good rubber. Also, new tires lose an additional several percent temporarily until they are broken in.
    In winter, both AUTO and this high temperature will have an MPG impact, especially in your non-highway delivery circumstances. But if you need the heat (or A/C in summer), you need it, so that is just a cost of using the car.
    #18 fuzzy1, Feb 20, 2017
  19. srellim234
    1,198
    1,687
    Laughlin, Nevada
    As expected, the mileage went way up yesterday. Spending almost two hours in rush hour traffic to L.A., an hour on the freeway coming back and the other running around the MFD is showing 147 miles and 50.1 mpg. Based on past history that means the car probably is between 47.5 and 48.5 mpg if I were to fill it up and do the calculation.
    How the car is driven makes all the difference in the world.
