  1. wackofamily
    wackofamily New Member
    sutherlin
    This is my first hybrid car a 2012 Prius 5. I bought it used in 2017 with only 40k on the odometer. Drove it for 3 years with no issues.
    Currently the car has about 140k on it.
    My issue that I am only getting about 35mpg.
    This started in January all in the same week I replaced the spark plugs, tires and got a oil change.
    Tires 205/65/R15
    Spark Plugs Denso SC20HR11
    New PCV
    Installed oil catch can
    Cleaned EGR pipe, valve and cooler.
    Cleaned intake, intake ports, throttle Body
    Clean the mass air flow sensor.
    Ran sea foam motor treat and engine cleaner multiple times.
    Had transmission fluid change back October 2019.
    No codes Dr Prius or My Foxwell Car scanner.
    Check for for brakes to see if they were dragging no issues
    I pulled the sparks plus yesterday and look good
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Tires are too wide affecting mileage
    Mendel Leisk, DHeuschele and Pluggo like this.
  3. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    Keep the tires pumped up to at least 40 psi.
  4. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Your info says you have a 2012 Prius 4.
    If it's a four, the charts I saw say it takes 195/65R15.
    If it's a 5, it takes 215/45R17.
    Neither one takes a 205.
    From the 2012 Prius brochure:
    Either way, you didn't mention if they are low rolling resistance and that can make a big difference even with the right size.
    Even with the right sized LRR tires, new tires will hurt gas mileage till they break in. Plus we don't know what mileage you were getting before. Did it go down by 4 mpg or 15 mpg?
    RMB and Mendel Leisk like this.
  5. bisco
    49,371
    what were you getting for mpg's the first 3 years?
  6. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    According to the subject title of this post, it says it went from 35 mpg to 40 mpg and Said its a 5 model but profile says trim 4. Not sure what else to believe :ROFLMAO:
  7. jerrymildred
    11,508
    14,109
    Tampa, FL
    "Went from?" My version doesn't have those words in the title. It's just a range with no context.
  8. bisco
    49,371
    no context? how priuschat like :rolleyes:
  9. wackofamily
    sutherlin
    I was averaging 52 mpg before.
    I don't think going up one tire size will decrease your gas mileage by 15mpg.
  10. bisco
    49,371
    agreed. i think you have a lot of research to do. there are so many systems on a prius that work synergistically.
    Grit likes this.
  11. bisco
    49,371
    use dr. prius and check the hybrid battery health
    get a load test done on the 12v at an auto parts store for free
  12. jerrymildred
    11,508
    14,109
    Tampa, FL
    Thanks for the added details. Agree that a 2% increase in circumference alone won't cause a 15mpg drop. We still don't know if the new tires are LRR. If they are, then there's definitely something else at play.
    I think I'd be making sure they didn't overfill the transaxle and also double checking all the hose connections related to the OCC installation.
  13. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    Even if the new tires aren't LRR and heavier? :LOL:
  14. ASRDogman
    ASRDogman Senior Member
    6,054
    3,251
    Are you CERTAIN you connected everything when you put stuff back together?
    Very easy to miss something. I would double check. Can't hurt.
  15. wackofamily
    sutherlin
    I was getting any from 49 to 52
  16. wackofamily
    sutherlin
    They are not LRR ,just Les Schwab house brand Tires. Before those I add set of Michigan non LRR
  17. jerrymildred
    11,508
    14,109
    Tampa, FL
    Never heard of "Michigan" tires. but I'm not really a student of that industry. Google can't find them either. ;)
    Still, if you were getting around 50 mpg on non-LRR tires, that's impressive. Changing to a different brand still has the potential to make a big difference, especially if they are a house brand that might not be made to the highest standards.
    Sorry, but it looks like no one will be able to give you anything like an accurate diagnosis over the internet -- just places to try looking. Hopefully, you're doing that in between visits here. If you do discover what is causing it, I know we'd all appreciate finding out so that info might help someone else in the future.
    wackofamily and ASRDogman like this.
  18. wackofamily
    sutherlin
    Dr Prius results. Good news. Battery and charging system is in good condition. LifeTest_2020-04-23_04-16-08.jpeg FullDiagnostic_2020-04-23_03-46-23.jpeg
    pjksr02, jerrymildred and bisco like this.
  19. bisco
    49,371
    well done, congrats!(y)
  20. wackofamily
    sutherlin
    Still getting 38mpg.
