36 mpg for the past 3 months - what should dealer check?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by smassey22180, Dec 22, 2014.
  1. smassey22180
    smassey22180 Junior Member
    37
    Sacramento, CA
    2010 package V (Uppercase V, not five, since its a 2010 and Roman numerals were used during model year 2010 to denote model) ith 40k miles. Still under Toyota extended warranty. We got 43 mpg this time last year. I think it got worse after the IPM recall which involved a complete inverter replacement for us. We drive mostly in the suburbs. We have 17" wheels so that is -2mpg for those. Air filter is new. Any ideas?
    thanks
  2. JC91006
    16,482
    8,397
    Did your inverter fail when you brought it in? I noticed this year my gas mileage has decreased a little too. Maybe the cheaper gas this year gives less mpg?
  3. smassey22180
    37
    Sacramento, CA
    We had the recall software update done in March and then the inverter failed in July. It took 2+ months to get the part in and we did not get the car back until Sept.
    thanks
  4. fuzzy1
    10,167
  5. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    If the 12 V battery has never been changed, you are about due.
    I would start there, whether it tests "good" or not.
  6. smassey22180
    37
    Sacramento, CA
    That is probably a good idea anyway. We are on our 3rd one for the 06 Lexus RX400h and they go without warning.
  7. bisco
    49,455
    some have lost 8 mpg after the inverter update.
  8. lester williams
    227
    68
    mississippi
    My mpg has been going down lately also. However, I think it is the $1.92 per gallon gas I am putting in it now---- and running lots faster in the interstate.........
  9. Mendel Leisk
    38,711
    We had the inverter protection update with no ill effect. But there's been a lot of reports here of marked mpg loss post-update. Maybe the software used for the update is buggy?
  10. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    This would have made me lose my mind do believe...
  11. bisco
    49,455
    i think it must be, because cars that weren't part of the recall, (i assume they had updated inverters) aren't showing decreased mpg's. i wonder what would happen if they compared two cars on the epa dyno test?
  12. Former Member 68813
    3,524
    981
    US
    brake pads and slide pins may need attention. but dealer will wait till they are all screwed up before doing anything.
