36 Psi?
Discussion in 'Gen 2 Prius Main Forum' started by NJaloha, Jan 18, 2008.
  1. NJaloha
    NJaloha New Member
    Ok, my wife's 08' base is 1 week old today. The tire pressure light came on yesterday. I checked with a gauge and her tires were running between 20 and 25 PSI.
    So we had to go to the dealership anyway to pick up some paperwork and they filled up her tires for her there, tire pressure light is now off.
    I was talking to a Prius tech and he said that you need to keep PSI at 36 YEAR ROUND.
    The owners manual says 33 in cold weather.
    What do you guys think/do with your tire pressure?
  2. patrickindallas
    patrickindallas Shire rat
    676
    36
    Vancouver, WA
    44 front and 42 rear at all times...
  3. patsparks
    10,664
    567
    Adelaide South Australia
    I run 42 & 40 F & R but it never gets cold enough to snow here.
  4. Bob64
    1,540
    92
    Virginia
  5. dulecki
    dulecki New Member
    25
    Western Michigan
    44F/42R here. Just had the dealer change the oil today... they helped me by setting 'em to 35/35. I'll have to remember to tell them not to do that in the future...
  6. Clubford00
    Clubford00 New Member
    93
    Buffalo Grove, Ill.
    Ive run as high as 50/50 (not recomended, its a harsh ride) I normally run 40/40 all the time, unless im in snow then i drop it down to 35/35 I live in Chicago and put about 200 miles a day on my car. it seems to work for me.
  7. Tideland Prius
    16,125
    According to the door jamb, it's 35/33.
    With the Integritys, I was running 38/36. (Max is 44PSI)
    With my Nokians, I'm running 40/38. (Max is 47PSI)
  8. Don-RI
    Don-RI Member
    153
    Cumberland, RI
    I follow the 42/40 practice year round (RI), and check the tire pressure once a month just to keep them tuned to the weather.
  9. BoHenriksson
    BoHenriksson New Member
    17
    Greensboro, NC
    44/42 on the original tires. Wear is even, handling normal, mpg great!
  10. MattFL
    MattFL Member
    163
    47
    The sticker on my drivers door jam for my 2008 Prius says 35 front, 33 rear so that's where they stay. :)
  11. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    I've always run 42-40 in mine, especially the OEM integrities. Toyota indeed recommends a lower inflation to cushion the ride, and IMHO compensate somewhat for the shortcomings of the Integrity tires itself. A higher inflation is certainly safe, and even the 42 or 44 psi as referenced by others above is well within the mgf. inflation recommendations for the tire.
    Higher psi will increase your mpg. In my experience on Priuschat, it seems that most folks use 42 front, 40 rear. Certainly 35-33 if fine as well, it just depends on what you want to accomplish. :cool:
  12. paulccullen
    paulccullen New Member
    276
    Seattle, WA
    Took my car in for a service recently. When it came back the tires were *still* at 42/40. What's puzzling me: Did the mechanic realize they were increased deliberately to improve FE so he left them where they were, or did he simply forget to check.
    Maybe I'll ask next time (Toyota of Kirkland, WA)
  13. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I'll bet the dealer never rotated your tires...
  14. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    the first time i took my 04 to Toyota of Olympia, the changed tire pressure to 35/33. the 2nd time, i told them to not change the tire pressure, they have not touched it since.
    when i got my 06, the first oil change i mentioned it to the mechanic, and he said he was advised to check the tires for low or uneven pressure only
  15. PRIUS007
    PRIUS007 James Bond -007
    133
    Mundelein, Illinois
    Another 44F/42R
    Ride is great and so is mileage.
  16. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    My Prius is set to the recommended 35/33. Our roads around here are so rough I refuse to bounce around at higher pressures, too old for that nonsense.
    The exception is winter driving, I typically run my studded tires at 30/30. For some reason, they offer better snow traction at that inflation. Ice traction is also better too, but that is probably due to the studs
  17. blamy
    blamy Member
    380
    Central Florida
    Another vote for 42/40 and I average a solid 51 to 52 mpg.
  18. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    As a tech, I usually recommend to ALL customers to find a comfortable median between the pressure listed on the sticker (min press) and the pressure listed on the tire (max press). I explain that more air = hard ride with better economy, less air=soft ride with less economy.
    And if I find tires set above the pressure listed on the sticker, I will keep them at that level. I generally do not lower pressures unless they are in excess of what the tire is rated for. I also make note of that on the repair order so the service advisor can give that info to the customer.
    And yes, if the RO says "rotate tires" I rotate the tires. Every time.
  19. Canuck
    Canuck Member
    605
    Vancouver Island,BC,Canada
    On our previous 2005 always kept tire pressures 44F and 42R and experienced improved MPG but slightly rougher ride. However, every time I took the vehicle in for service they were always adjusted to the 35/33 level and was told that for warranty purposes that was what they had to set them at.
    Just recently picked up the 2008 and was told the same thing. Only solution is to set them myself.
    Gary
  20. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    45/45. I don't check the tp often & didn't notice a difference when the tires softened due to the lower temps.
