37r tail light bulb?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by HiccaBurp, Sep 21, 2014.
  1. HiccaBurp
    HiccaBurp Junior Member
    49
    Vernon Hills, IL
    After 7 years, I'm changing my first tail light bulb on my '07 Touring. The bulb is a "37r"? Not a common bulb. Is there a replacement for these?
    Thanks!
    prius_nerd likes this.
    51,140
    my daughter picked up a pair from the local auto parts store for her '08, no prolemo. 5 bucks i think.
  3. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Don't go by those markings on the bulb. You need to walk the bulb into your local auto parts store, or go to a chain tire/repair store (ie Firestone), to double check.
    Toyota vehicle owners manual says its a 5Watt, wedge base bulb. LINK
    Buy the LONG LIFE version and change both sides (right and left). Why? The other side will burn out soon. It will also be dim compared to the new bulb; this is esp noticeable with headlight bulbs and tail brake light bulbs (which doesn't apply to Prius b/c LED).
    Philips 12961;
    Osram Sylvania 2825; $7 Amazon
    HiccaBurp likes this.
  4. AceDeuceCoupe
    AceDeuceCoupe Junior Member
    35
    LA
    Is it an easy DIY to change bulbs? I have my first one on my 2007 tail light also.
