3k trip what to do before the trip
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gotrock20, Oct 7, 2011.
  1. gotrock20
    gotrock20 Junior Member
    FL
    i am about to go on a long trip Miami to CA. 2700 miles.
    what should i do before i go? oil change?
    what to expect?
    I'm planning to drive like 2 or 3 hrs and take a 15 or 20 min break.
    Any suggestion on when to take break, fill gas, tired pressure..... ect... during or before ?
    Thank You
  2. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    There is no reason to change the oil before you go unless the next oil change would be due well before your trip is over.
    Use whatever tire pressure you normally use, preferably someplace between the door jamb pressure and the sidewall pressure.
    Fill the gas tank before you run out when you know you can still make it to the next open gas station. If you're a nervous nelly that fills at 1/2 -1/4 tank, keep doing that so you can stay in your comfort zone. If you normally run your tank lower, be aware that it can be a longer distance between stations in the West.
    A break every 2 or 3 hours is reasonable, although I usually go at least 3 hours.
    Carry something to drink with you, water is best. I prefer to not eat while driving, it's easy to stuff your face with too much food while you are just sitting there driving. You will also need less food while driving, 3 full meals will make you sluggish. Eat smaller amounts at least 3 times a day.
    Pick some places/things to see/do on the way. Setting and meeting intermediate fun goals makes the trip seem less formidable.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    The longest road trips I've done are ~860 miles, one way or a roundtrip of ~525 miles, each way. Oil change depends on whether you're due for it or might need it in the middle of the trip.
    Besides checking your tire pressure, do so for your spare. Check that you don't have any low fluid levels. Make sure you bring a flashlight, tire gauge and electrically operated air pump along, in case you get a flat. Uhh.... as for gas, run it as low as you feel comfortable, keeping in mind how far the next gas station might be.
    I'd bring along some fast music along w/audiobooks, podcasts or streaming audio (spoken and music), if available (e.g. NPR News app, Pandora, etc.)
  4. Patrick Wong
    18,200
    6,474
    1. Check all engine compartment fluids and replenish as needed. If any routine maintenance is overdue, have that done now.
    2. Bring along windshield washer fluid.
    3. Check the tires and replace if marginal. You don't need to have a high-speed blowout and be stuck on the side of the road.
    4. Tire pressure should be checked when the tires are cold, before you have driven on them that day.
    5. My personal policy is to refuel and take care of the car before I take my driving break. You'll have to decide what works for you.
    6. Regarding when to refuel, I suggest you do so at 3 bars; frequently highway signs will show when you can expect the next gas station (of course, you are counting on that station being open...)
  5. Tideland Prius
    16,153
    Check to see that all the lights are working (taillight, brake light, parking lights, indicators and low/high beam).
    Fruits are good to snack on on the drive. Get something easy to eat (e.g. grapes or peeled oranges).
    Know your route beforehand. Check the route on paper so you have an idea of where you're going.
    This is in addition to what has already been said.
  6. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Don't worry about the car, but you need to take care of yourself. Sleep in a real bed every night.
