3rd Gen Front Wiper Motor Runs constantly when engine on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by WAWAWA 2011 Prius, Jul 7, 2025 at 11:49 PM.
  1. WAWAWA 2011 Prius
    WAWAWA 2011 Prius New Member
    Monday
    Long Beach, California
    Help!
    The front wipers were not working at all, replaced the fuses, still dead. So today replaced the motor and now the wipers run constantly whenever the engine is on.
    Looked up several posts, many think it's the Wiper Relay. However, I've gotten 3 different locations reported for where the relay is located. One says in the interior fuse box. All I found are fuses, I replaced any related to the wipers. Another post says its a component of the wiper motor itself. So how do I check it or replace it?
    The third is a diagram that shows the location behind the display screen. I don't want to try and take that apart if this is not the correct way to find/check/replace a faulty relay.
    Help! For now the wiring harness for the motor is unplugged, but I need to find a solution so my wipers will work!
  2. Mendel Leisk
    40,574
    Can you change the wiper speed, intermittent, low or high speed?
  3. Tombukt2
    Tombukt2 Senior Member
    12,193
    2,150
    Durham NC
    Wen ever engines on . . Not likely you mean anytime ready is displayed .engine need not be running or if it is AC probably on ..sounds like combination switch . And slip in wiper dial at all?
  4. Mendel Leisk
    40,574
    Info:
  5. ChapmanF
    17,326
    Or do you mean whenever the car is ON? (What happens if, starting with the car OFF, you press the power button two times without touching the brake pedal?)
    I kind of suspect the park-position switch inside the wiper assembly. If you confirm at the wiper motor (using a backprobe)* that there is no voltage at pins 1, 3, or 4 (red, darker green, or unstriped white), and only voltage at pin 2 (light green) while this is happening, then it kind of has to be that switch. It's inside the assembly and meant to conduct all the time except when the wipers are in their parked position (to make sure they go back there, no matter where they are when you turn the switch off). If you replaced the whole assembly, maybe you got a bad one. Or, if you had it disassembled in some way to replace just the motor, maybe re-checking the reassembly might be all you need.
    If you are looking at sources that tell you gen 3 has a wiper relay, let alone give you different places for this supposed relay to be, you need to be more selective about the sources you look at.
    Toyota Service Information and Where To Find It | PriusChat
    * Edit: forget I said backprobe. Better to just unplug the connector (at a time this is happening) and probe the pins in the wire harness connector.
    If you backprobe while the connector is plugged in, even if voltage is only being supplied at pin 2, you'll end up seeing it at pin 3 anyway, and possibly some voltage at other pins also.
    Brian1954 likes this.
