3rd Gen Prius buzzing noise.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cuongly267, May 27, 2020.
  1. cuongly267
    cuongly267 Junior Member
    Philadelphia
    haven’t drove the car in a month. Started it today to let it run. This buzzing noise is now present and will not go away.
  2. Mendel Leisk
    40,575
    A lot of PriusChatters post videos about this-and-that sound, and almost invariably I can barely hear anything, or have to ask "is it that slight noise at 26 seconds? I think I hear it."
    Not in this case; what the hell is that?!?
    pjksr02 and Johnny Cakes like this.
    51,141
    the radio? but seriously, your info says 2005. what year 3rd gen, and how many mies?
    i would charge up the 12v and see what happens
  4. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    It sounds like the key alarm when you try to walk away with the car still turned on, or when you open the driver's door with the car running. I'd begin by slamming the door a couple times and checking to see if the dome light is responding properly. And, what was that flashing red indicator?
  5. cuongly267
    Philadelphia
    I drove the car a few times around the block noise is still there. The red light indicator is for the parking brake.
    I’ll try it opening and slamming all doors, hood and rear hatch tomorrow.
    I’ll check the dome light tomorrow also.
  6. Hitech51
    Hitech51 Junior Member
    Houston, Tx
    2013 Prius v wagon
    Pull the error codes, I suspect it might be the ABS system which could be a small part or the main module,,,,
