3rd gen Prius where is upper radiator hose???
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kobear18, Oct 12, 2021.
  1. kobear18
    kobear18 Junior Member
    92
    23
    san francisco
    Where is the upper radiator hose?
    Ya after 5300 miles, P261B code came up again. In May, I had head gasket problem. I poured the Head gasket sealer in. Its called the Bar's leak. It has worked 5300 miles until now. Last year, I did the same and it lasted 10 months. The bar's leak worked but now I think it clogged the radiator. I opened the lower drain valve, its just dripping drop by drop, I knew its probably clogged. The car run find in low speed for about 30 min usually. After 30min, it started to over heat a lil bit around 195 to 220. Up hill and free way is a NO NO.
    The head gasket should be sealed by now. What is left is to clear the radiator. The heat core seem ok because I still got heat for about 20 to 25 min. After it started over heat, the heat went away. Its all weird I know.
    I'm semi sure the radiator is clogged. I forced the water pump to go bad so now I just ordered a new pump. But I think the main thing is to clear the radiator. Where is the upper radiator hose?
    Menal said they called it the No. 2 hose. That No. 2 hose is the bigger hose connected to the thermostat right?? I would like to ask what is the other hose connected to the thermostat?? The upper radiator hose at the lowest left hand corner of the radiator if you are facing the front of car. The lower radiator hose is actually on the right side 2 to 3 inches above the drain valve. So if I want to do a radiator flush, I need to feed the water through that and open the drain valve?? That should flush the radiator??
    In the mean time, I would also like to ask what are the 2 hoses connected to the reservoir expansion tank?? 1 upper hose and 1 lower hose.
  2. ChapmanF
    18,546
    The "upper" radiator hose is always the one that takes hot coolant from the engine to the radiator.
    The "lower" hose takes the cooled water from the radiator to the thermostat.
    The "upper" one is not very "up" in this layout, but you can see it has callout 16571C.
    Of the hoses to the reservoir, the one colored red here fills the system when coolant is poured into the reservoir. The blue ones carry air bubbles from a couple of the system's high points and returns the air to the reservoir.
  3. kobear18
    92
    23
    san francisco
    So the coolant go in from radiator through 16572D to engine block? Its very hard to get to 16571C so I guess flushing the radiator is difficult.
    The strange thing is that I got bubble come from 16261H the lower hose of reservoir. I got air in the system I assume? I only saw bubble come from there when its at 195 or above though.
  4. ChapmanF
    18,546
    Yes, but only when the thermostat opens.
  5. kobear18
    92
    23
    san francisco
    hhmm...but that doesn't make sense though. When thermostat open, the hot coolant from the engine block should flow to the radiator and fill up the radiator and then go back to engine block.
    I saw most of the you tube vids on how thermostat works. When thermostat open, whatever that hose connect to the thermostat should be going into the radiator. Moreover, there is no driving force to push the coolant from the bottom of the radiator to the thermostat and then to the engine block by 16572D. That hose is at the lowest point. what drive the coolant upward then. I understand there is the system pressure but ...hmm......im getting more confused now
  6. ChapmanF
    18,546
    The system is full of coolant all the time (except when you're filling it and bleeding it). The thermostat only controls where it does or doesn't flow.
    The thermostat is in the elbow you see there in the lower left (where it says "refer to illust #2 of 2"). That part is called the water inlet, and it feeds directly into the inlet of the water pump.
    The water pump forces the coolant through the engine block, and up into the cylinder head. The coolant is hottest where it leaves the engine from the end of the cylinder head. All you see of the head in this picture is the water outlet pipe up in the top right ("refer to fig. 11-04 PNC 11101"). That hot coolant runs through the pipe 16577C and "upper" radiator hose 16571C, passes through the radiator, and having been cooled, returns to the water inlet through the "lower" radiator hose 16572D.
    But when the thermostat is closed, no coolant is taken from that lower 16572D hose. That's the only significant exit from the radiator, so when it is blocked by the closed thermostat, coolant doesn't flow through the radiator. That doesn't mean there isn't coolant in the radiator; it just isn't moving.
    So you might be wondering what the coolant is doing while the engine warms up and the thermostat hasn't opened yet.
    There are several hoses not shown in this picture.
    You can see the water inlet has a second, smaller nipple on it. That's the bypass inlet, and the thermostat does not block that.
    The cylinder head has a couple more nipples on it, not shown in this picture, where hot coolant exits. One of them just feeds a skinny hose to the throttle body to keep it from icing. The other one is larger, and sends hot coolant on a path that includes the heater core in the cabin, the EGR cooler, and the exhaust heat recovery system under the car.
    Both of those paths, through the throttle body and the other stuff, join up on the way back to the water inlet bypass. So during engine warmup, the coolant is flowing all of those places. Just not through the radiator. The hot coolant returning through the bypass inlet does flow past the thermostat, which is how the thermostat can sense the temperature. Eventually it opens, and then coolant also flows through the radiator.
  7. kobear18
    92
    23
    san francisco
    thank you so much for such a in depth explanation OMG!!!! Hmm...I will see if I can take the upper radiator hose off and flush it from there. It seem difficult though. I already tried the lower hose but couldn't force the water into it. I guess I may have to just replace the radiator. 270k miles, its time!
    #7 kobear18, Oct 13, 2021
  8. Boston2008Gen2
    Boston2008Gen2 Junior Member
    59
    Houston TX
    Kobear18, Did you fix the overheating issue? I am getting P261b , no heat on passenger side driverside is hot, Hear googling noise under dash, just bought the car, New WP and Thermostat. I can't seem to get air out did try nutabolts video. Still same i#ue
  9. ChapmanF
    18,546
    Are you still getting P261B ? If so, need to figure out what's up with the new WP.
  10. Boston2008Gen2
    59
    Houston TX
    I changed WP since i was getting "Overheat" symbol in Dashboard - So I changed WP. Now with new WP, I am getting P2601P: Here are the symptons:
    1. Googling noise underdash board. Warm heat in passenger side but driver is hot.
    2. I was driving <55mph for an hour no issues. While returning I drove at 67/68mph and i got P2601.
    3. No rattling or engine noise what so ever during startup.
    4. I bought this car(2012 Prius V) since it had 98k miles on it and I totalled my 2008 Prius - This is my third Prius. I love prius but then this happened!
    Back to your question, What you want to check on new WP ? This is OEM from Toyota Dealer. Do you think installation wasn't proper? Please let me know.
  11. ChapmanF
    18,546
    Are you getting a different code, or did you just mistype something in the above? I thought it was P261B earlier.
    Troubleshooting a diagnostic code is always a matter of making sure to find out what the code's actual detection condition is, and then looking for whatever reasons the ECM could have seen that condition. It's a common mistake to think that if a code has a fortune cookie with "water pump" in it, it means you have to take the old water pump out and put a new one in. It can mean that, but if you do that, and still have the code, then it probably didn't.
    The detection condition for P261B is that the ECM thinks the pump is turning less than 900 RPM when it should be turning faster than that. The ECM gets that information over the wiring that brings the pump's tachometer signal back to the ECM. Some details on how that all works are in this thread.
    Another recent poster tracked a similar issue (P261C in that case) back to a damaged wire at the water pump connector. I say that not to predict that your solution will be the same, only as an example of the kinds of places the troubleshooting can take you.
  12. Boston2008Gen2
    59
    Houston TX
    I apologize. Yes correct error code is P261B.
    New WP is running less than 900 RPM ? What i should do next? You don't think there is Air pocket in my coolant? (reason why i have no heat in passenger side?). I am open for anything for a fix.
  13. Mendel Leisk
    41,901
    Maybe all this is due to Bar's Leak? Try running a 50/50 white vinegar/water flush?
  14. Boston2008Gen2
    59
    Houston TX
    Just drain all the coolant & fill with 50/50 white vinegar/water - do the 30 mins procedure with maintenance mode & drain it?
  15. Mendel Leisk
    41,901
    Pretty much. Can you see goop, say if you extract a little from the reservoir, or drain an ounce or two from radiator bottom spigot. If you can get a few "lumps", test them with a 50/50 mix before you do a flush, see if it will in fact dissolve them.
    This suggestion was from one of the product manufacturers; @cnc97 knows which I think.
    One thing: if you do the 50/50 flush, and then follow up with a straight water flush or two, you're left with a dilemma: how to get back to a 50/50 coolant/water mix. Toyota Super Long Life Coolant only comes pre-mixed 50/50 (55/45 in Canada btw), but Toyota Long Life Coolant (without the "Super) is full-strength, compatible, just it is recommended to change sooner, roughly half the interval. Accordingly, I think you could, after several straight water flushes:
    1. Drain system
    2. Look up system capacity, then add half that amount, of Toyota Long Life Coolant.
    3. Complete fill with distilled water.
    4. Drain/refill the system sooner than usual next time, say 2 year or 25K miles.
    The elephant in the room is the head gasket?
  16. Mendel Leisk
    41,901
    Here's system capacity, from page 501 of Prius v Owner's Manual:
  17. ChapmanF
    18,546
    "The ECM thinks ..." are key words you have to be sure not to leave out. When you see a P261B, you have to consider all of the reasons the ECM might think the pump is running less than 900 RPM. It only gets that information over a tachometer wire; it never had an opportunity to crawl out of its box and across the engine compartment and look at the pump and say "yup, that's really turning less than 900 RPM."
    There are some who post on PriusChat and often suggest that ECUs just make trouble codes up randomly (because mumble something supply voltage mumble). That's not really the case. But it's also not the case that everything an ECU thinks is the final God's-eye-view picture of the situation. You really have to begin troubleshooting by looking up what information the ECU gets and how it gets it, and then start your troubleshooting tree with possible branches for all the reasons it could have for thinking what it thinks. You prune those branches off one by one as you work through the diagnosis.
  18. Boston2008Gen2
    59
    Houston TX
    I put an OEM WP, Thermostat & Coolant (Long life) and then i got P261B. So if i test my coolant, i am not going to get any lumps. When I drained my old coolant - that was still pink in color, i did see some sediments - I still have those old coolant in the container.
  19. Boston2008Gen2
    59
    Houston TX
    My Android APP with bluetooth adapter - reads coolant temperature. Inbound 1 hr trip on hwy at 55mph, Max reading was 199.5F. Outbound i tried at 68mph, the reading shoot up from 199 to 217 and i got the P261B. I pulled to side, within like 5-8mins, temp came down to 165f (since its in 60s here). Then drove rest of 1 hour less than 50 MPH, coolant stayed at 197f. Came back home!
  20. Boston2008Gen2
    59
    Houston TX
    Let's say I have air pocket or clogged coolant somewhere - will this set P261B code?
    But as per ECU, WP rpm is less than 900, right? This means I don't have clogged coolant line but WP is bad?
