4.. 1/2 quarts for ATF Fluid?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gobux, Oct 19, 2010.
  1. gobux
    gobux Junior Member
    60
    Columbus, OH
    Just went to my toyota dealer and gave them 4 qts of ATF Fluid. I got the bill and they said they had to "Add a qt" saying it took more than 4 qts but not quite 5..
    Is this right?
  2. bobg1400
    bobg1400 New Member
    Virginia
    It depends, I am assuming that you don't have a 2010 Prius. I just changed my fluid today and it only takes 3.8qts
    I have a 2004
  3. gobux
    gobux Junior Member
    60
    Columbus, OH
    I have a 2005.. it cost 106 total, but that was with a $10 coupon. So, they charged $116 for 5 qts of ATF and labor. I just don't get where the "over 4" came from.
  4. bobg1400
    bobg1400 New Member
    Virginia
    Then I do believe that it should only be 3.8 qts..... how much for labor? Its a quick and easy job....It took me around 20 minutes. I payed $32 for the Oil.
  5. gobux
    gobux Junior Member
    60
    Columbus, OH
    Maybe the spilled a bottle.. I have no idea if they even did the service. The dealership is like a secret lair for the service dept. You can't see inside or anything.
  6. Patrick Wong
    18,200
    6,492
    4 US quarts is the 2G transaxle fluid capacity.
  7. gobux
    gobux Junior Member
    60
    Columbus, OH
    Why do they have to fit their stereotypes so well? I'm sick of this.. I go to Firestone 3 days ago and they try to put a different oil in my car then what they say, now the actual Toyota dealership is gouging me for 8 extra bucks.. seriously, where can I find someone who isn't dishonest?
  8. AbuS3ood
    AbuS3ood Member
    113
    Jordan
    i did it my self took 3.8 qts, its very easy and DIY
    next time search the forum and you will find it in details.
  9. edwardob
    edwardob Member
    227
    33
    ireland
    i think the reason there is a diference is because if you do it yourself there is usual a small amount left behind not drained out.the garage will drain it all which is about extra cupful or so.
    i find 4tins did my 2005 prius and even some of that overflowed.
  10. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i did it myself. it cost me 50 dollars or so.
  11. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    I have learned to listen to Patrick Wong carefully for accurate info. From Toyota repair manual:
    This matches exactly what he has said earlier.
    When I changed mine I poured in 4 qts but some drained out. So 4 qts should be enough for DIYers. Good luck! :)
  12. Mr.Vanvandenburg
    1,327
    544
    2020 Prius Prime
    Around here in north central CA the two dealers I asked wanted 11.50 per US quart. They said it was the new price. I would guess to say they were just generally annoyed at you bringing your own oil and spoiling their fun so charged you an extra quart for nothing. Dealers often have an attitude of the customer is always wrong. So they proved it by telling you you brought too little oil for them to perform their duty. We know, you don't, attitude. As for draining it all out, I know I let my oil drain a lot longer than the dealer would.
  13. 2009Prius
    2,705
    511
    63
    Toyota dealers use a special lift to tilt the car forward 45 degrees to drain all the ATF out. I bet you will lose by a long margin even if you let it sit for a week. :bounce::pound::rofl:
  14. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
    A good independent mechanic is your best bet, someone who depends on word-of-mouth and will make things right, rather than faceless corporations that have a monopoly (dealer) or marketing/coupons (Firestone). The quality of service declines exponentially with the number of service bays.
