4.4kw Battery has a bad cell
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by avongil, Aug 22, 2019.
  1. avongil
    avongil Member
    67
    56
    Easton, PA
    I ran the Dr Prius app and it is showing that one cell is not working. This makes sense since I only have about 9 miles of range.
    Is there a source where I can just buy just one known good cell? I really do not want to buy a salvage battery and then install it, see if it has bad cells then swap cells.
  2. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    Interesting.... Do Toyota service centers have a way to see the same information?
  3. avongil
    avongil Member
    67
    56
    Easton, PA
    I'm sorry its the block voltage I am getting a reading not the individual cell and its only 1 volt less. Does anyone have the acceptable block voltage limits for the 3rd Gen EV battery?
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    It's been a while since I looked that that on my PiP. And now that I've traded it in on the Prime, I no longer have access to it. But I seem to remember seeing around a volt on mine sometimes. Are you getting a code or a light?
  5. bisco
    52,368
    1) your car is under warranty
    2) there's nothing wrong with your battery
    3) 9 miles is average for most users
    4) no one has ever worked on the pip battery, do you have any idea how much it weighs?:eek:
    noonm and jerrymildred like this.
  6. avongil
    avongil Member
    67
    56
    Easton, PA
    Understood. Thanks!
  7. jerrymildred
    11,517
    14,157
    Tampa, FL
    Yup! And a whole lot more.
    CaliforniaBear likes this.
