4.5 years 95k miles - new battery?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by letsgobobby, Oct 8, 2016.
  1. letsgobobby
    letsgobobby Junior Member
    32
    2012 Prius, battery gives us no problems but would you replace the battery at this point?
  2. JC91006
    16,482
    8,400
    It'll only cost you $200 if you do decide to do it, why not
    kenoarto likes this.
  3. xerox6135
    xerox6135 Member
    170
    93
    michigan
    Bought my 12 volt battery off amazon for 100.00 it is a ac Delco and yes it is made for the prius perfect fit
  4. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    I've typically seen my batteries die around the 5 year mark, so replacing yours at this point is a smart move. Nothing's worse then having to deal with a dead battery away from home at an inconvenient moment.
    I've purchased my batteries from Walmart for my cars. They've been completely reliable for me, and are more competitively priced.
  5. bisco
    49,500
    no, mine is the same age, only 47k, but i check it once in a while, haven't drained it, and am in it for the long haul. why pile good batteries on the recycling heap?
  6. Mendel Leisk
    38,728
    @letsgobobby This is the 12 volt battery you're talking about?
  7. letsgobobby
    32
    yes, the main (non-hybrid) battery
    I usually buy batteries from Costco. and will probably do the same.
    At 4.5 years and 95k miles I guess it's done it's job.
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    so long as it is a S46B24R battery, you should be able to buy it from several vendors.
    Costco does not seem to sell car batteries online, so I have no idea what is in store.
  9. Mendel Leisk
    38,728
    I'd suggest to test it first. At a minimum monitor it's voltage with a digital multimeter, a digital load tester is better, test the cold cranking amps.
  10. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    Go buy it at CostCo, its a lot cheaper and has better warranty. Battery's only last 5 years and below. So if you want, drive it until you feel like it's about to die and replace it.
  11. Mendel Leisk
    38,728
    ^ Yeah, it is getting up in age.
  12. Bluegrassman
    Bluegrassman Active Member
    229
    185
    US
    2012 with 107k miles on original battery. No issues thus far, but I plan to replace it before January.
  13. KennyGS
    1,243
    1,044
    Keystone State
    In my mind, whatever additional life you might wring from a 4.5 year old battery will be mitigated by replacing it now, instead of at a less convenient time and circumstance. In fact it could end up being more costly if you have to use a road service.
    I'd rather be under my hood while it's sunny and 72F, than dreary and sleeting.
  14. letsgobobby
    32
    Costco doesn't sell the battery, at least not the Costcos near us.
    Consumer Reports rated the Diehards well but on the Sears websites the ratings are terrible.
    What battery should I buy? I looked at some installation instructions on line and it looks pretty straight forward.
  15. orenji
    orenji Senior Member
    5,884
    3,486
    I replaced mine and it was 6 years old, and still working fine, but I did not want to push my luck. Installed a new Toyota battery, one made in Japan. Most new batteries come from Mexico and don't last.
    Bluegrassman likes this.
  16. letsgobobby
    32
    where did you get it from?
  17. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    Get one of these three. Toyota or Bosch IMO.
    AC Delco, $117, 2yr warranty, no proration.
    Amazon Link
    Bosch, $143, 4yr warranty, no proration; Car Batteries | Pep Boys | Battery Installation | Car Service
    Toyota True Start, $181; San Bernardino & North Hollywood Toyota online. Ask local Toyota dealers to beat or match.
    Toyota Parts - Discounted Toyota and Scion Parts and Accessories
    7 year pro-rated warranty Toyota Battery - Genuine Toyota TrueStart Factory Warranty Replacement Batteries
    84-month service replacement warranty
    24-month of roadside assistance reimbursement
    Years 1-2 100% of parts, service and towing
    Years 3-4 50% of Truestart MSRP*
    Years 5-7 25% of Truestart MSRP*​
  18. tpenny67
    tpenny67 Active Member
    464
    402
    Massachusetts, USA
    Just a data point here, not a recommendation: The battery in my Mustang was last replaced in 2006. It's garaged most of the time and usually not driven in cold weather. Also, my recently junked Chevy pickup (note to self: update sig : ) had a battery from 2004. 12V batteries can last a very long time, particularly if they're not used every day.
    But that's a bit of an apples and oranges comparison. The Mustang should have minimal parasitic load (no smart fob and crank windows!) so the battery is only used to start the engine. Unlike the Prius, it gets a load test every time you crank the engine on a cold morning. When it's not eager to crank, it's time to replace the battery. Also, if the Mustang suddenly doesn't start one cold morning I'll just drive the Prius :)
    I have a ScanGauge on the Prius which can be used to monitor the 12V voltage. To give it a "load test", press the start button twice with the foot *off* the brake. This will boot all the computers but not engage the HV battery. If the 12V voltage is still above X volts, it's probably still good. Anybody know what a good X value is?
  19. xerox6135
    xerox6135 Member
    170
    93
    michigan
    That would depend on what load you put on the battery. I replaced mine when the resting voltage was at 11.9 volt. My prius was a 2013
  20. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    Walmart is notorious for telling American manufacturers that they must relocate manufacturing to China. When Trump talks about stolen American jobs, no entity has been a stronger force behind this migration than Walmart.
    I hope you don't mind that I mentioned this. Here's an excellent article about the phenomenon:
    The Man Who Said No to Wal-Mart | Fast Company | Business + Innovation
    No doubt those jobs aren't coming back to America, and this migration may have all be inevitable, but Walmart worked hard to accelerate it.
