4 errors on dashboard no power
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Damian2898, Mar 22, 2023.
  1. Damian2898
    Damian2898 New Member
    Uk
    Four Touring
    Hello i have problem with my prius gen 4 hybrid, while i am driving i got 4 errors and car going to N and it wont go to D j have to disconnect baterry for 5 minutes to reset, can anyone help please :(
    I have already changed water pump as one mechanic said thats the issue but its not :(
    52,385
    start with a free 12v load test at autozone. is it original?
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    There are two separate coolant systems, one for the gas engine (larger tank on the left side) and one for the electric drive (smaller tank on the right side). Hybrid system error and subsequent shutdown of the drive system could occur if the inverter coolant system is not working and the car is protecting the electric drive. Also, in addition to the warning screens, you need to pull the codes to be sure.
