4 full quarts of 0W-20 in a 2004: engine overrev expected?
Discussion in 'Gen 2 Prius Technical Discussion' started by mikepaul, May 26, 2009.
  1. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    Extra revving sound from a standing start. Sure, I dislike the extra .1 quart but up until now I hadn't heard anything out of my engine when it happened. This is my first use of Mobil-1 0W-20 and I'm wondering if anyone else who had been using 'thicker' oil like 0W-30 noticed any change in engine revving after the changeover...
  2. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    I had an '04 since new, sold it about 6 weeks ago. For most of its life, it ran on Mobil 1 0W-20
    No difference whatsoever in engine sound, certainly nothing like what you described. I switched from 0W-30 to 0W-20
  3. dogfriend
    7,512
    1,185
    Carmichael, CA
    I've been using 0W-30 for the last two oil changes. No difference in any way compared to 5W-30.
  4. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Wouldn't want to run 4 quarts, as 3.9 already showed to be overfull. Makes you wonder if it is sucking a drop or two of oil in to the airflow meter sensor now and then.
    I only put in 3 quarts (Mobil1 5W-30) during my last oil change, mileage is way up over where it was in similar weather last Fall with 3.5 quarts. Of course the car was new enough then that the tires and such might not have been fully broken in. I'm not planning to do test runs with increasing oil levels to find out...
  5. dogfriend
    7,512
    1,185
    Carmichael, CA
    Yes, as we have discussed in other threads, 4 quarts is too much. My car takes 3.7 qts to get to the top mark - several people use 3.5 or even 3 quarts and still end up in the acceptable range.
  6. jayman
    13,439
    639
    Winnipeg Manitoba
    My Prius, 3.3 litres put the level right at the full dot
    The Prius isn't the only Toyota that will be overfilled with the owner manual/shop manual oil capacity. My FJ Cruiser, the book states that an oil/filter change requires 5.2 litres.
    If you actually put that in, the level is about 4mm over the full dot. Five litres has the level about 1 mm over the full dot
  7. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    I remember someone (Patric Wong?) observed oil consumption after switching to 0W20. Don't know how common it is or whether it is a problem.
  8. jayman
    13,439
    639
    Winnipeg Manitoba
    I switched my '04 to 0W-30 synthetic at around 10,000 miles. At around 20,000 miles I switched to 0W-20 synthetic. Running the oil 10,000 miles, the level went down perhaps 3 mm on the stick
    Patrick's engine may have more wear, in which case using a lighter oil will result in oil consumption. I don't think he bought it new
  9. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    what was the recommended oil? 0W-30 or 20? I've been running 20 for so long i've forgotten until the last change and the dealer put in 0W-30. I think I can tell a difference, not in engine sound but a little performance or mileage maybe, or maybe its just me........
  10. dogfriend
    7,512
    1,185
    Carmichael, CA
    For US cars (NHW-20), Toyota recommends 5W-30. However, as Jayman can tell you, they recommend other viscosity ratings (including 5W-20) in Europe, Japan, et. al.
    It really depends upon your local temps and conditions. I am sticking with 30 as the hot viscosity rating because of the high temps (>100°F) that we have in Sacramento in the Summer. I use 0W-30 because it is priced the same as 5W-30. It may have a slight advantage in FE at lower temps, but I haven't seen any noticeable difference.
  11. jayman
    13,439
    639
    Winnipeg Manitoba
    Running either a 0W-30 or 0W-20, you probably wont have a noticeable FE gain until the temps dip below 0 F
  12. mikepaul
    1,763
    Columbia, SC
    Well, I have another 4 quarts of 0W-20 but my mom's 2007 Civic Hybrid uses that so I'll just get more 0W-30 for my next change.
    And I'll go back to pouring out some oil before I go so they can't add more than I want.
    Thanks...
  13. dogfriend
    7,512
    1,185
    Carmichael, CA
    My car didn't even see 32°F this winter. I have the Explorer to go to the snow with.
  14. jayman
    13,439
    639
    Winnipeg Manitoba
    You won't notice any difference then, running a 0W-30. Won't hurt, but no gain either
  15. richard schumacher
    7,663
    1,038
    United States
    Give them three full quart bottles. Then there will be no waste, no overfill, and no fooling around with partially empty bottles.
  16. jayman
    13,439
    639
    Winnipeg Manitoba
    That works too
  17. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
