4 New Ecopia EP422 P185/65R15 122732 Initial Report
Discussion in 'Gen 2 Prius Fuel Economy' started by bobodaclown, Sep 6, 2013.
  1. bobodaclown
    bobodaclown Member
    216
    72
    Hello All,
    I didn't rotate my earlier tires. They were not Ecopia tires or LRR tires on our 2009 Base Prius. Got about 35K out of them, the backs were cupped and the front had worn outer edges. I neglected my rotation duty. WOW were they noisy.
    I had 4 Ecopia EP422($87+ fees) tires installed total was $520 after a $70 rebate and a 3 year alignment ($100).
    What a day and night change in the noise level, and performance in general. They grab in the rain much better. Also the speedometer and GPS speed match up now at 50 mph there was a 1-2 mph difference with the speedometer reading higher.
    This is my initial report. I've got about 79k miles on the Prius. I'll try to keep updates. Overall happy.
  2. sportcoupe
    sportcoupe Junior Member
    44
    Check your tire pressure. I'm sure the shop only put 30-32 psi in them. I run 48/46, front/rear in Ecopia's for better mpg.
  3. bobodaclown
    bobodaclown Member
    216
    72
    I asked for 42/40. So far so good.
  4. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    I just bought the Ecopia 422s for my 08 Prius, and have several posts in another thread about it.
    My wife also has them on her Honda Insight.
    These are fabulous tires for the money. They are perfectly quiet up to 70 mph--not a sound. Very smooth, quiet ride--like the old Cadillacs and Buicks of the 50s--when GM was supreme.
    I paid $370 at Tirerack including postage to local Sears. $44 for install plus $32 for lifetime rotation/balancing.
    I will rotate every 5K or 6K miles, as the book says, to keep tires quiet.
    With $70 rebate, these tires are cheaper than the Integrity OEs--an inferior tire. So far, it looks like gas mileage is a standoff--though after some wear maybe an improvement.
  5. PriusSport
    1,498
    88
    SE PA
    I'm using 38/36 as in the OE Integritys I had previously. Average 45-50 mpg, depending on season. They did set 38/36 at Sears--which they won't do at Toyota dealership, in my experience, even thought you ask them to.
  6. bobodaclown
    bobodaclown Member
    216
    72
    So far so good after about 1000 miles.
  7. dorunron
    dorunron Senior Member
    3,318
    1,104
    Houston, TX
    What's your MPG like?
  8. bobodaclown
    bobodaclown Member
    216
    72
    Before the display would consistly list 44-45, after 49-50.
    Computed millage 43 now 46.
  9. dorunron
    3,318
    1,104
    Houston, TX
    Not bad, more than likely once your tires are broken in you should get a little more out of it if you hyper mile. As I have said before, the Ecopia's were #2 on my list. I went with the more expensive Michelin Energy Saver A/S and am very pleased. If you are interested in the MPG on those, look at my fuelly stats. I have posted two of them showing the difference between the stock Integrity and the new Energy Saver's. Best of luck to you!
  10. barbie.gee
    barbie.gee Junior Member
    70
    Chicago, IL
    I just got new Ecopia's on my 2005 Prius this past Monday, at Costco. Original tires had almost 50k on them, and even though I was good about rotations, the fronts were very worn on the outer edges, so it was certainly time to replace them.
    It was $440 out the door. (Chicago proper; $15/tire install, plus a state "disposal fee" per tire.) They pumped them to 35/33 with nitrogen, but today I'm going to have the alignment checked and done, and I'll see if I can get the local Midas to pump them up to 40/38 or at least 38/36 for me.
    What's the dealio with nitrogen? Can they be topped off with just air? The boyfriend and family all tell me nitrogen filling is kinda smoke and mirrors; not bad, but not really special, either, so what's the point...
  11. Patrick Wong
    18,200
    6,479
    Agree. If it is not convenient for you to visit Costco, just use compressed air.
    barbie.gee likes this.
  12. FreydNot
    FreydNot Member
    210
    37
    Seattle, WA USA
    Did you get the $70 off discount? I've been waiting for the $70 off deal to switch back from Michelin to Bridgestone.
    I believe the theory is that nitrogen will not leak out as quickly as normal air. Really it's a feature that Costco throws in at no extra cost to differentiate themselves from the other tire stores.
  13. wjtracy
    wjtracy Senior Member
    11,335
    3,596
    Northern VA (NoVA)
    The Nitrogen is very nice feature of a COSTCO tire change... your tires will hold pressure better than air.
    However, I would personally just refill with air after that. Your tire will remain Nitrogen enriched since the Oxygen permiates faster. You still have to check tire pressure and refill when necessary.
    Nitrogen is not smoke and mirrors, it leaks much more slowly than oxygen. But the magnitude of the benefit, given air is already 79% Nitrogen, is not that great. If it was free and easy to get it would be the best thing. But don't pay big bucks, that's the hype. Also there are some other false claims made sometimes.
  14. barbie.gee
    70
    Chicago, IL
    Yes, I got the $70 off. In Chicago, the sales taxes are high, as is the "tire recycling fee" or whatever they call it.
    I have to look at the invoice again, but I got the impression the nitrogen wasn't free, but they also didn't ask me if I wanted it or not... Maybe it's easier to keep a canister of "nitrogen" than running a noisy compressor for air?
  15. eldoprius
    eldoprius Junior Member
    They say it has something to do with moisture in the tire and that they stay inflated longer.
    Watch out for the Ecopia, Costco had to replace my first set after 10K, uneven tread wear. Only got 35K out of the second set and this was because of uneven tread wear. Never had this problem with Michelin who lasted a ling time but were extremely noisy. I have 256K on a 2006 and so far the best I have had was Toyo. Trying Kuhmo ECO now and am very happy so far only had them for a short time and they are very quiet and it gets better mileage than the Ecopia. The Kuhmo's are about $400 out the door at America's tire.
  16. alanwagen
    alanwagen Member
    121
    79
    FORT WORTH
    2018 Prius
    I replaced Goodyear Fuel Max with the 422's. The Bridgestones are so much quieter. So far we like them. I had to order them from Discount Tire but they came in fast and I should get some rebates.
  17. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Air is 78% nitrogen.
    nemebean likes this.
  18. scotty80
    scotty80 Junior Member
    I also bought these Ecopias, and I was pleased with the traction in snow. This was my first winter with the Prius, but I was surprised that they gripped so well.
  19. oldscooterguy
    oldscooterguy Junior Member
    Ohio
    Replaced Tiger Paw tires last summer with Ecopias. WOW!! MPG went from 52 to 56, (I run them 44/42 psi), great traction in rain and snow, shorter stopping distance, and quiet.
    I'm sold on ecopias. When my wife's Prius needs tires there is no doubt what is going on hers.
    Don't think you can beat the price/performance ratio.
  20. bobodaclown
    bobodaclown Member
    216
    72
    Just an update 87500 happy with tires. 50 mpg.
    AT100 ? HD
