4 New Struts for 2005 Prius?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Pat Horwath, Apr 10, 2014.
  1. Pat Horwath
    Pat Horwath Junior Member
    Purchased a used 2005 Prius a few years ago with 100,000 miles. Mileage is now close to 170,000. Moved to a rural S. Calif. high desert area last year and need to ride on bumpy dirt roads to and from home about 8 miles round trip (3-4 times per week).
    I get maintenance from a trained Hybrid dealer 80 miles away (Napa repair place) rather than a Toyota dealer. The desk mechanic noted I needed 4 new struts, that they were badly worn (but didn't write this on the invoice which my old mechanic would do). They verbally quoted $1500 to replace all four struts. I was a bit in shock and not ready to say ok without getting a second opinion.
    Going through previous forum topics someone noted that if Vin # is J it was made in Japan and struts should last longer. I'm assuming riding on the dirt roads has has its toll on the struts. I plan to have a local mechanic check the struts for wear (not a hybrid mechanic) and possibly do the repair if needed.
    I'd appreciate any thoughts on what to ask the second mechanic. This place is also a Napa parts place but highly recommended by a friend for honesty and quality work in the area.
    I appreciate any thoughts regarding new struts for a 2005 Prius with 170,000 needing to ride on bumpy dirt roads. Thanks. Pat
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    The Prius is made in Japan from parts supplied from around the world. There have never been any made in the US or any other country that I know of.
    In any case, any strut ever made will be worn-out at 170K miles.
    But, $1500 seems rather expensive for parts and labor. A quick look on the Internet gives the following prices:
    Monroe front struts $58 each ($15-20 extra each for misc parts)
    Monroe rear struts $69 each
    KYB front struts $67 each ($15-20 extra each for misc parts)
    KYB rear struts $80
    I can't see how it would take more than 4 hours total for labor. The total should be less than $800.
  3. Patrick Wong
    18,200
    6,492
    My thought is that it is not surprising that your Prius needs new front struts/rear shocks, and you should call around to see the best price you can get. Further, for a complete job more than the front struts/rear shocks need to be replaced. The strut top bearings and the rubber insulators above and below the coil springs also need to be replaced. $1,500 would not be surprising for Toyota dealer service or someone who prices as if they are a Toyota dealer service dept.
    Considerable disassembly is required: the front cowl tray and all of the hatch trim have to be removed for access. I've posted on how to replace the front struts and rear shocks. The labor content is significant.
    The question of whether the Prius is built in Japan or not is irrelevant given your odometer reading.
  4. JC91006
    16,672
    8,518
  5. Patrick Wong
    18,200
    6,492
    It would not surprise me that the part numbering changed in 2006. You should rely on the dealer parts catalog.
  6. JC91006
    16,672
    8,518
    The parts catalog lists the shock at only $30.xx, I find that really cheap for an original Toyota part. I was thinking what you ordered before was a "kit" and had more items to it
  7. Patrick Wong
    18,200
    6,492
  8. JC91006
    16,672
    8,518
    I'm going to order the 06 parts, seems cheap enough to change out. Patrick, you mentioned there are other parts that should be changed out at the same time, can you list those parts out on the catalog so I can order them at the same time?
    Also is there a difference in the right and left side parts?
  9. Patrick Wong
    18,200
    6,492
    The front left and right struts are different part numbers. The rear shocks use the same part number for left and right. Here is my thread regarding how to replace the rear shocks:
    Replaced Rear Shocks | PriusChat
    For a complete job, replace the upper insulators on the rear struts (6 on the exploded parts diagram.)
    The upper and lower insulators on the front struts should be replaced (16 and 19 on the exploded parts diagram) as well as the strut mount (22 on the exploded parts diagram). The strut mount especially should be replaced if your odometer reading is 100K miles or more.
    Here is my thread regarding the front struts:
    Hints Regarding Replacement of 2G Front Struts | PriusChat
  10. JC91006
    16,672
    8,518
    This 06 doesn't have that high of mileage but it's pretty beat up. It truly is a working project. The left rear shock has been leaking and I guess this is a good a time as ever to get that out of the way. At least I know this will be done correctly and getting all the necessary parts changed out.
    As always, thanks for your valuable input.
  11. Pat Horwath
  12. Pat Horwath
    Thanks Patrick and others,
    This was helpful information. The shop quoted $1,000 for the repairs by phone. I'll bring it in on Monday to let them check the car first and give me a direct quote and see what parts they plan to use. Repairs/tires/ etc., cost higher in this area since we are rural. I appreciate all the feedback.
    Pat
  13. JC91006
    16,672
    8,518
    I think there was a problem with the parts catalog at camelback, after I placed my order their catalog is now offline.
  14. Patrick Wong
    18,200
    6,492
    The catalog is back now as of this writing. I've also edited my post #9 above to include links to my "how to" posts regarding the rear shocks and front struts.
  15. JC91006
    16,672
    8,518
    Bought my shocks from Camelback and was all prepared to install them this weekend. Got bored this week and I ended up browsing on here and found some signal mirrors I thought looked cool and would add safety to my car. Upon reading some threads about the mirror and the installation, people were mentioning a person in South El Monte (very close to me) that installed the mirrors and was really good at his job and charged really good prices. I looked him up and found out he does suspension (lowering) and audio work. Called him up and asked if he would replace rear shocks because mine were leaking (he's not a mechanic so had to ask), he said sure since he had all the suspension tools. Quoted me $80 for labor to replace my rear shocks. I was like :D scored!! Brought it to him today and this guy has done so many Prius car's suspensions, he could have done mine with his eyes closed. Took him 50 minutes and he was done. Happy ending for everyone!!
    Total cost $31 x 2 shocks
    rubber insulator $10 x 2
    labor $80
    Total $162 to replace 2 rear shocks. :D
  16. billh
    billh Junior Member
    27
    cleveland
    Would Monroe provide good exhaust replacement in addition to struts? Need both for my 2006 package 6 (I think one of the addons with package 6 was an improved ride -- not sure). Want to make sure I have the correct back-pressure with a new exhaust.
