4 qts in transaxle and no overflow
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by av8erdunn, Jan 4, 2015.
  1. av8erdunn
    av8erdunn Junior Member
    78
    Mobile AL
    I am changing the translate fluid and read it should take a little under four qts. I put four qts in and it didn't overflow any. I did use a little pimp that screws onto the bottle kinda like a hand soap pump but there isn't hardly any left in the pump so I didntmlose much there. Any ideas? And yes I'm sure I put it in the correct hole.
    Edit- never mind. Just checked it and it's about 1/16-1/8 below the lip. It should be fine. :)
    #1 av8erdunn, Jan 4, 2015
  2. JC91006
    16,673
    8,518
    You should be fine with the 4 qts
    51,154
    the translate takes a pimp more.:p
  4. Mendel Leisk
    40,584
    <deleted, didn't notice this is second gen forum>
  5. kevin3
    kevin3 Junior Member
    25
    Sacramento, california
    Did you check it on a hill?:D
  6. alekska
    alekska Active Member
    435
    138
    Atl
    The car was not perfectly horizontal when you were filling.
    - Alex
  7. Mendel Leisk
    40,584
    This DIY thread says the refill spec is 4 quarts. If that's the case, and you've not spilled any, you should be good.
    Toyota Prius: How to Change the Transmission/Transaxle Fluid - PriusDIY.com
    In the link he really dwells on determining the right refill quantity by measuring what came out. This seems a bit misguided, I mean, it could be low to begin with. My method, with 3rd gen, is get the car level, pour in 'till it starts coming back out, then let the overflow subside for a while, then replace the bolt, good to go. With 3rd gen that's around 3.5 liters, in my experience.
  8. av8erdunn
    78
    Mobile AL
    Gotta love auto correct. Guess I should have read it before posting. LOL
    And yes it was on ramps when it was filled so I am sure that has something to with it.
