4 warning lights came on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lpf, Jun 24, 2021.
  1. lpf
    lpf Member
    113
    33
    Greece
    Today all the pictured lights came on steadily. I have noticed that a pump works very often last month and today I've heard it during driving. Brakes are working ok. What to look for except fluid?
  2. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    Accumulator?
  3. lpf
    lpf Member
    113
    33
    Greece
    If you mean 12V battery, actually it is in lower voltage than normal I think
  4. rjparker
    rjparker Tu Humilde Sirviente
    7,964
    4,709
    Texas Hill Country
    He means your brake booster hydraulic accumulator. It has a pump to build hydraulic pressure for your drive by wire brakes. An accumulator stores hydraulic pressure so its immediately ready. A leaky accumulator or a bad pump or a bad master cylinder will throw codes and is dangerous.
    You get the alarms before it fails completely. Unfortunately, it is a common problem in older Prius vehicles.
    TheLastMojojomo, lpf and Valiant V like this.
  5. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    Sorry, no - I mean the brake accumulator that stores pressure to operate the brakes.
  6. lpf
    lpf Member
    113
    33
    Greece
    Is it the same as they call it brake actuator?
    Valiant V likes this.
  7. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    The brake system on the Prius is pretty complicated compared to most vehicles, so unfortunately, you're exceeding my pay grade with that last question. It's possible that the accumulator is part of the actuator, or an ancillary component.
  8. JC91006
    16,482
    8,397
    LOL. Well at least you're willing to say that. Yes the car is pretty complicated once it starts developing problems and warning lights are all lit up.
  9. ChapmanF
    15,569
    Just read the trouble codes and find out why the lights came on. The codes can be posted here. Smile at all of the nice guesses about what your problem is that are posted before we know the codes.
    If you don't have access to a scan tool to get the full story, you can get the two-digit blink codes with no special equipment, as a bunch of threads around here describe.
  10. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    What is the measured voltage?
  11. lpf
    lpf Member
    113
    33
    Greece
    12.3-12.5V before power on. When in ready it's about 14.0V (according to the MFD)
  12. lpf
    lpf Member
    113
    33
    Greece
    I will scan it at the local Toyota dealership (I also plan to check the traction battery too) as I have no tool to access to codes.
  13. ChapmanF
    15,569
    Not a bad plan. You also have easy access to two-digit blink codes without any special tool, in case you want to know something before the trip to the dealership.
  14. lpf
    lpf Member
    113
    33
    Greece
    How I can do that? Do you mean use the MFD diagnostics mode? Thnaks
  15. dolj
    dolj Senior Member
    7,648
    3,858
    Wellington, New Zealand
    No, he means to find abbreviated blink codes using the Blink Light method.
    See this post for how to do that: Prius Gen2 Blinking Lamp Example
    Read through that first post so you get an idea of what to look for in the video. There is no soundtrack explaining what is happening. Also, choose a wire with nice clean, firm, and reasonably flat ends so you don't cause any damage to the terminals at pos 4 and 13.
    OBDII Position 4 and 13:
    Post back here with which lights blinked what codes if you want help.
  16. lpf
    lpf Member
    113
    33
    Greece
    Checked at the dealership today. No faults, ABS block works fine, dashboard lights switched off, no charge at all.
