4 warning lights- trouble running- advice?
Discussion in 'Gen 2 Prius Technical Discussion' started by Katie Conlan, Sep 7, 2014.
  1. Katie Conlan
    Katie Conlan New Member
    Nashville, TN
    I have a 2007 Prius with about 150K miles. This morning, no warning lights were on and I drove about 20 miles no problem. Later, when I turned the car back on, the Master Warning Light (triangle of death), yellow brake warning light, VSC light, and engine check light were on. The automobile outline with the exclamation (!) in the middle was on the energy monitor as well. I looked in the manual and it said if the lights were yellow I could drive, so I did, and at first everything was normal, but after about 5 miles, when I would stop the car and try to accelerate, it would accelerate very slowly even with the pedal to the floor and the engine was loud. Once I got to about 45 it was fine, but getting there was difficult. When I drove up a hill, the speed decreased. The energy monitor showed nothing going to the battery, and the battery had one level left when I reached my destination. A couple hours later, I started it again and it charged the battery back up to blue while the car was sitting. I also took it for a test drive and it drove fine, but all lights were still on. I checked the inverter water pump (there was turbulence so it appears functional). I also tested the 12V battery. 11.8-11.9 on ACC with headlights off. About 14.1 with car on.
    In short, symptoms:
    -Master warning light, VSC light, yellow brake warning light, and engine check light
    -Car slow to accelerate with pedal to floor, battery drained to one level while driving, no energy going to battery
    -after sitting for a couple hours, battery recharged and drove fine, all lights still on
    Any ideas on what could be the problem?
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    You need to get the codes read. Considering the mileage, the symptoms are similar to what occurs with a failing hybrid battery, or one that is overheating. Did you hear the battery cooling fan running in the back seat? While the 12V reads a little low, I am guessing that is not the cause of the situation. Toyota reads the codes for a fee. Autozone may have a Prius compatible reader, no cost usually. If you can get the codes read report them back here for more advice.
  3. Katie Conlan
    Nashville, TN
    I am taking it in to Toyota tomorrow, will update when I know anything new. I did notice the fan in backseat (forgot to mention it in my original post). It is loud and noticeable; it wasn't before. Could that mean it is overheating? Do you know the difference in repair between an overheating battery vs. a failing one? Do both require replacement?
    51,155
    it's the same thing. the only hope you have is that the fan is clogged, and not able to properly cool the battery. otherwise, the battery is probably toast.
  5. walpoleauto
    walpoleauto Junior Member
    48
    Walpole, Massachusetts
    If the check engine light is on, you should be able to pull the codes without the need for the dealership. How old is your 12v battery? Also, do you hear a fan noise coming from the rear as you drive (kind of sounds like static coming from a radio)
