4-ways flashing continuously
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Stracgan C, Mar 8, 2018.
  1. Stracgan C
    Stracgan C New Member
    Ontario Canada
    The hazard lights flash without warning continuously. The faster the car is driven the faster they flash. The dealer thinks the cause is related to moisture on the abs module quoted 3-4k with no guarantees...Any ideas?
  2. Mendel Leisk
    40,576
    That's a bit nervy...
    Apart from the speed related factor, could it be a defective hazard button?
    51,142
    welcome!
    pull the fuse.
    NutzAboutBolts likes this.
  4. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    how fast you have to drive so they're on steadily?
  5. Stracgan C
    Ontario Canada
    Not sure ...but it's worth a check
  6. Stracgan C
    Ontario Canada
    Yes they are on steadily. We had to pull the fuse to save the battery
    We did...we were concerned it would drain the battery. Thx
  7. bisco
    51,142
    sounds like a computer/wiring issue, could be tough to find. hate to say this on a 7 year old car, but i'd just leave the fuse out before giving a dealer thousands for a fishing expedition.
    maybe call toyota to see if they can be helpful in any way.
  8. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,601
    1,690
    Bay Area
    You should get an electrical diagram and trace where the wires are and see if you can find a fault somewhere between the wiring. Check each wires for power and see which one stays on and such. It’s hard to diagnose online. You’ll need the right tools to trace it as well.
    Raytheeagle likes this.
  9. AzWxGuy
    AzWxGuy Weather Guy
    1,036
    519
    Tucson, AZ
    2021 Prius
    Could some liquid have spilled into the button that activates the hazard flashers? The button is located on the flying bridge pretty close to the cup holders. No accidents or body damage anywhere? Rodents chewing on wiring? Lastly, check the state of charge on the 12V battery.
  10. Dave79
    Dave79 New Member
    Pittsburgh
    I have same issue on gen 3. Did you ever find out what the issue was?
