40,000 Service Questionable Charges
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by barriec7, Mar 3, 2014.
  1. barriec7
    barriec7 New Member
    Athens, Georgia
    I've been around Prius Chat since 2011, and it has served as a wonderful resource. 40,000 trouble free miles later I took my Prius in for service. The dealer not only did the 40,000 required service but added on their 'recommended' service without asking me. I am sure I signed something so don't intend to fight this, but want to learn for the next time. My gut tells me that Toyota's 'required service is sufficient and to skip the dealer's 'recommended services', some of which are directly below.
    Specific charges that raised eyebrows:
    a. Rear drum service (Clean and adjust brakes): $51.95 (recommended was inspect). They did not inspect the brakes and then indicate that the brakes needed adjusting…they simply went ahead and did it.
    b. ZAK oil additive: $7.95 (minor but I didn't even think oil additives really help).
    c. Cleaned battery terminals and added anti-corrosive battery pads: $27.64 (I am quite capable of cleaning my own battery terminals but this is a Prius so I don't really know if this was important or not…)
    I'm reasonably experienced (do all my own motorcycle maintenance) but no expert. I find myself (again) in the netherworld of wanting to give the best care possible to the car without spending money pointlessly. Any Prius gurus care to comment?
    Thank you. Barrie.
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I'm no Prius expert. I'm due for my 40k mile service in a few months. I plan to have it done at the dealer. Every place I've gone to has always quoted me a cost prior to doing the job and if it costs significantly more, they will call me. There is a print out receipt that I walk out with when they take the car as proof.
    Oil change, tire rotation, and whatever inspections are all I plan to do for $70.
    iPhone ?
  3. Mike500
    Mike500 Senior Member
    2,593
    766
    Sounds like they padded the bill to make money off you.
    I would NOT go back there.
    PriusGuy32 likes this.
  4. ETC(SS)
    6,958
    There's an old saying.
    Pigs get fed....Hogs get butchered.
    FWIW, this dealership smells more like a pig than a hog.
    It sounds like they padded your bill by about 100 bucks with unwanted/unneeded service. Believe me....I've seen MUCH worse!
    It's sleazy but you basically have three choices:
    1. Let them do the maintenance and put the "giveacrap" switch in the "don't" position. The Prius is a pretty frugal car to own, and the maintenance schedule is pretty light. They'll take a nip at your wallet every now and then, but you'll be rewarded with not having to worry about it.
    2. Educate yourself about the maintenance items, and demand a detailed explanation for requested work that's not on this list. If it's not on the maintenance list? Then it's not maintenance....it's a REPAIR.
    Those require an explanation, prior approval, parts get a forensic exam...etc.
    If you're going to use this dealer and stay with the Toyota brand then I would confront the maintenance manager and give them about 20-minutes of grief about the unwanted extras.
    I would start off by insisting that they use more qualified technicians since the 2011 Prius, IIRC, is a 3rd Gen Prius. They don't have rear drums to service. If the technicians "looked" at the brakes while they already had the wheels off??? That's nice, but I don't recall a line item in the maintenance schedule @ 40K for disc brake cleaning.
    The battery terminals are a little interesting as well, given the location of the Prius and the Aux battery (Georgia, and the interior of the car, respectively.) How much did the terminals corrode in 2y/40k???
    Why did this happen?
    The oil additive should be IMMEDIATELY removed.
    Not because it will be bad for the motor (it won't) but because it was added without your permission.
    If the OEM oil is so good that nothing else should be used in a Toyota, then why add anything to it? :)
    This will put them on notice that you're at least paying attention, and you have another 10,000 miles to start boning up for the 50K service.
    3. Buy about $100 bucks worth of tools (they don't need to be Snap-On) and learn to do as much of the maintenance/repair work as you can. It's not nearly as daunting a task as the wrench swingers will lead you to believe that it is. If you can spell and you have broadband?
    You can maintain cars.
    Rednecks do it drunk all the time. ;)
    That's basically it in a nutshell.
    I did the 45,000 mile maintenance on my dear wife's mastodon yesterday.
    It probably took an hour longer than the folks at the shop would take, but it cost me $30 in parts and $0 in labor, and I used about $50 worth of tools.
    That may not work out for you, but if you can't afford option #1????
    Hang out here on this forum and avail yourself of option #2. :D
    Good Luck!
    DadofHedgehog and mmmodem like this.
  5. Mike500
    2,593
    766
    Over 40 years, ago, I took my first used car in for service.
    After having that done, I was so disappointed in the quality of the work, having redid half the work, I started to learn and have done it ever since.
    The free Toyota service for the first 2 years was NOT EVEN up to my standards. Oil was always overfilled and clips were loose on the oil change door.
    So, if you are finicky, doing it yourself is the best option.
  6. bisco
    51,154
    pic of the anti corrosive battery pads?:)
  7. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    LOOK at what you signed.......if that is even possible now.....and see what was on it.
    If those items were NOT on it, demand a refund and if they get snotty, mention that States Attorney.
    If they WERE on there .......shame on you.
    I would have no problem with the brake work. Experience tells me that drum brakes need to be cleaned.
    (Does it REALLY have drums in the rear ??)
    Item #2 is pure BS. I never put anything into my oil these days.
    The battery terminal thing is good too .......IF they noticed corrosion.
    I think you probably will be hard pressed to find ANY dealers shop that won't "recommend" things that
    aren't really needed these days. The sleazy part is sneaking them in on you.
  8. Mike500
    2,593
    766
    Anti-corrosive battery pads?
    $1-2 and 10 minutes to install.
  9. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    2011 Prius doesn't have drum brakes. They gave it too you. You should always just say EXACTLY what you want done. NEVER say do the whatever miles maintance.
  10. bisco
    51,154
    i would definitely go back and demand a refund on the drum brake clean and adjust, or contact your states ag office for consumer affairs, that's outright thievery.
  11. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    You should go back, demand you speak with the maintenance manager, and the the drum BS as a reason to refund your money on those other 2 BS services.
  12. Mike500
    2,593
    766
    The time to have contested the charges was when you got the bill and went to pick up your car.
  13. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The owner's manual is very clear on what's part of a 40K service. There's no reason to let a dealer do anything more than what's on that list. But once you agree to those items, there's no reason to expect your money back. According to the OP, they DID ask first. ("I'm sure I signed something")
  14. Mike500
    2,593
    766
    Yeah! It's readily apparent that he bought and paid for the pig.
  15. PriusC_Commuter
    914
    307
    2014 Prius Plug-in
    I agree he definitely won't get his money back about the oil additives and battery terminal crap. But if they supposedly did a service on "drum" brakes, when his car has disk brakes, I still think he should hound them about it. Possibly it was a typo, or maybe the service adviser at that dealership knows nothing about the Prius model and wrote up the usual BS. But either way he should make it known to the manager that he's upset with this kind of crap and won't tolerate it again. It won't cost him anything but some time to make a complaint. Just my two cents.
  16. barriec7
    barriec7 New Member
    Athens, Georgia
    Thanks for the replies. What really got my attention was the drum brakes...and it was definitely specified as drum brakes. Also...in my slight defense, I have all service done at this dealer and they never added oil additive before and never snuck anything in.
    I showed up said give me the 40k service and signed the release (which was blank...she whipped it out without making any notes...and I doubt she knew I just happened to be there for a 40k ...no appointment).
  17. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Its also possible they they have some "40K service" package with a discounted price, in which case you didn't actually pay "extra" for those items. Its not always easy to tell from the invoice.
    Perhaps a lesson learned? Ask first?
  18. Okinawa
    Okinawa Senior Member
    1,333
    317
    They ripped you off. If I were you I would find another dealer. Just an oil and oil filter change for me. I change the cabin filter and engine air filter myself when needed and that's it for me. I do rotate the tires about every 7,000 miles.
  19. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    I think the rear disc may also contain a drum brake for the parking/emergency brake.
    iPad ? HD
  20. Easy Rider
    982
    210
    N. Central Florida
    And I think that is absolutely WRONG.
