40mpg?
Discussion in 'Gen 3 Prius Fuel Economy' started by prince, Aug 2, 2018.
  1. prince
    prince Junior Member
    52
    17
    Atlanta, GA
    I bought the car at a little over 60k and was getting around 50mpg. Now it has a little over 130k and getting 40mpg. New Interstate battery and replaced all 4 tires with Bridgestone Ecopia EP20. Any ideas? Thank you in advance!
    52,755
    tire pressure
    a/c use
    air and cabin filter
    throttle body
    egr circuit
    intake manifold
    spark plugs
    injectors
  3. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Wait, does the cabin filter affect gas mileage?
    52,755
    can reduce a/c effectiveness, requiring higher settings. couldn't put a number on it though.
  5. jaspernuts
    jaspernuts Junior Member
    25
    32
    Madison Lake, MN
    I cleaned my egr circuit and intake and jumped from 45 to 50 mpg.
    mjoo, James Powers and prince like this.
  6. jmccloskey
    jmccloskey New Member
    Stoughton, WI
    I'm at 203K on a 2011. Last fall I had my fuel injectors cleaned, EGR valve and intake manifold replaced before finding the issue was actually the head gasket, which I also had replaced (ouch!!)
    This spring I replaced a rear wheel bearing.
    Last couple months I noticed MPG drop to about 32MPG. Noticed I wasn't rolling on a hill like I'd expect to when in neutral.
    Found rear brakes were pretty much siezed. Replaced calipers, rotors and pds. Up to about 48-50MPG now.
    Hopefully I'm good for a while!
    bisco and prince like this.
  7. prince
    52
    17
    Atlanta, GA
    I poured some techron fuel cleaner thinking it may not do any good and I'm getting 45mpg now, still not where I want to be but it's something. I typically replace my cabin air filters every 10k miles. I replaced spark plugs at 120k.
    I have never even heard of an egr circuit before. I haven't touched the intake manifold or injectors.
    jaspernuts - I may be where you were now, did you clean yourself or take to someone? If so, how much was the cost?
    jmccloskey - 203k on the same year as me, very impressive! How is your hybrid battery?
  8. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    Prince, were you getting 40 mpg over a handful of tanks or just 1 tank? How much did the mpg drop right after the new tires were put on and what is the psi?
    And about the Techron, did you increase 5 mpg on the next tank after using it? Was this the first time you used this type of product, and if not, what were the results the previous time?
  9. Pdaddy
    Pdaddy Member
    160
    49
    I experienced a 3 mpg drop going from conti eco to the bridgestone eco tires that you have.
    SM-G920V ?
  10. Exiled conservative
    Exiled conservative Junior Member
    30
    Whittier, ca
    How do you clean the egr circuit and intake?
  11. bisco
    52,755
    see the nutzaboutbolts youtube video
  12. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    ALS, James Powers and bisco like this.
